Cheers, I’m seeing ones like the link below for $80usd lower but don’t want to buy fakes.I purchased accumulators from jdp-planet.com directly from the website. They also have a eBay storefront. They are legit. Others have ordered it from them with positive experience. Also impex japan and have legit parts. I ordered and received parts from them as well.
Speaking of the rubber meeting the road...I was thinking of up-sizing from 285/50/20 (31.2") to the far more common 275/60/20 (33").
Pluses: more sidewall + an additional inch of clearance
What are my negatives, specifically speedo error?
Going from stock to 33s for most folks the speed will actually be closer to accurate. It's typically under by a few mph.No one has figured out how to adjust the speedo. I just know that I'm going 5% faster than it says.
Longer studs will not be a failure point assuming you install studs of the same diameter and material strength as the originals. More thread engagement for the lug will reduce the chance of thread tear-out.Any engineer folk want to chime in on whether or not stud length is a potential failure point?
I want to extend studs by a 1/2” up front and 1/4” in rear. Im assuming clamping force takes all shear stress out of the picture correct?
If theres something more im missing or just wrong please let me know.
Also a hardness recommendation wouldnt be terrible.
Thanks
It's likely these clips that are little boogers that put up a fight. If you pick them just right with the tool or a small plier, they will come right out. But it takes some familiarity with them. They're easily enough to replace if you choose to get savage with them.I'm trying to get to the filter for the charcoal canister after one has had a LRA tank installed.
I know it's behind the passenger wheel-well, next to the fuel filler neck and I need to remove the plastic cover. I have used the torx head to remove the crews holding the platic cover on, but it's still pretty firmly attached.
Is there a trick to removing it? Or are there clips on that plastic part that will release if I pull hard enough.
I figured it safer to ask here before applying too much force and breasking something.
For those with aftermarket bump stops: how in the hell did you remove the factory forward ones? Specifically the rear of the forward pair. I was able to twist off the front ones with a big channel locks, but the rear won't budge. My truck is a 2018 and lived its whole life in the desert and doesn't have an speck of rust anywhere. Are the factory bumps installed with permanent thread locker? I stopped short of putting a pipe wrench on them as someone else om here sheared one off I thought I read in a thread a bit back.
Ok I guess I'll try to be less of a wuss as the next step. It was at the end of a long day after installing BB sliders solo and I was in no mood to end the day by snapping anything so I gave up when it was taking a level of force that felt uncomfortable. I'll drop the front tires too and make sure I can get proper leverage as I was under the truck on my first attempt. Just in case I shot some PB Blaster in from the top to see if that helps any. Crossing my fingers that I don't end up in the "how do I drop my LCA so I can drill out a snapped bump stop stud" thread...Monkey wrench and more leverage. Mine weren't bad but it's very possible they can get corroded as water tends to pool behind them.
It was easy. I paid Slee to do it when they installed my lift.For those with aftermarket bump stops: how in the hell did you remove the factory forward ones? Specifically the rear of the forward pair. I was able to twist off the front ones with a big channel locks, but the rear won't budge. My truck is a 2018 and lived its whole life in the desert and doesn't have a speck of rust anywhere. Are the factory bumps installed with permanent thread locker? I stopped short of putting a pipe wrench on them as someone else om here sheared one off I thought I read in a thread a bit back.
I set up a Bluetooth OBDII dongle with phone app. On a dedicated view I have reported speed, 6% adjusted reported speed, and GPS speed. Did this to verify differential between reported and actual with 285/75/17 setup to get to real fuel consumption. It's not fancy like a speedo hack, but assuming plus 6% on speed becomes natural. And I have more range confidence when the tank gets low, which is compounded by never filling up fully.No one has figured out how to adjust the speedo. I just know that I'm going 5% faster than it says.
Zip stretch tape!In the jack storage cubby in the cargo area of our LC’s, there is a 2” hole going from the storage area to the undercarriage of the car.
See pic below.
I think because I have an extra set of wires running through that grommet, it’s wide open and letting too much dust in.
Does anybody have a good suggestion on how I could seal the hole up?
I am planning on simply using duct tape, but there has to be a more elegant solution.
KLF!Zip stretch tape!
Another product I did not know about.I used Sugru.
