SQOD Squad - Stupid Question Of the Day
I seem to recall the country of manufacture dictates which side the filler is on, but I couldn't swear to it.
1990 911 is on the driver (left side). Both my 2007 and then 2015 911s are on the passenger (right) side.
Existential Stupid Questions:
If the opposite of pro is con, then is the opposite of progress, Congress?
Why are they called "apartments" when they should be called "togetherments"?
How long does it take a giraffe to throw up?
100s have it on the drivers side. 200s on the passenger side. Both made in Japan. I don't know that it means anything.
I have a feelingits all disappointingly less intriguing & non-standard...
Bee cuz... -Practically No one ever stopped a car purchase becais of which side the cap sits...and I think designers know that... so I suspect it just ends up on whichever side is easiest to route to for each design...with all the other important underbelly stuff getting the real attention...
:meh:
Anyone running a snorkel on their LX570 (2017+ model)?
Can't seem to find 1 that suits the 3UR-FE here in Aus
I love having the filler on the passenger side. It's usually easier to find an empty pump at the gas station!
:meh:
Gas caps on the passenger side means it’s a better vehicle. 🤣 I was going to give a decent answer to the reason why but this link below gives a more detailed answer and explanations from the actual car companies
The obvious solution to this national problem:
1542690715557-png.64326
:meh:
Could be fake news, but there are several sources that seem to say similar things to what I'd heard.
The one below also supports what you said about the variability.
Here's one:
"Basically, the location of the fuel cap depends on whether there is right- or left-hand traffic in the country where the car is built.​
If the car is designed for right-hand traffic, the fuel cap is on the right and vice versa. The very simple reason for this is that in the event of an emergency, such as running out of fuel away from a gas station, it is safer to refuel the vehicle with a canister on the side facing away from traffic.​
Japanese cars, for example, often have left the fuel cap on the left side, as Japan has left-hand traffic. This also has advantages in right-side driving countries. Firstly, it is far less likely that you’ll forget to close the lid and secondly there is no danger that the driver’s door is damaged by careless other drivers. Many drivers also find it easier to have the cap on the same side as the driver’s door.​
This is just a rule of thumb as most manufacturers vary the side of the vehicle where the fuel cap is. This often relates to the design of the vehicle, especially the undercarriage, as this dictates the location of the fuel tank. There are also legal requirements as the location needs to be unlikely to ignite during a crash – this rules out placing the gas cap at the back of the vehicle."​
That messes me up every time. Both my vehicles are different and I have to look at the little arrow in the dash to remind myself as I pull up to the pump.
This is a possible solution :doh:
Must be nice to pump your own gas whenever you want. I only get to enjoy that experience outside of Oregon where it takes 10x as long to fill up with only 3 attendants for a 3 bay Costco gas station.
That's just a random picture, but yeah.
Haha, every time I drive through Oregon I try to have enough gas to get back outside Oregon before I need to fill up again.
The last time I didn’t quite make it through and not only did I face that delay, but the attendant decided to wipe the salt, dirt and gunk on my back window with a dry dirty rag. 🙁
Wow. I went looking for this thread and it was 6 pages back so I guess the collective intelligence is increasing 😂.
In any case, I actually have two stupid questions:
1) If I want to get power to the rear underside of the truck (near the back bumper), what path is recommended to run the wire from the engine bay?
2) Is there a relatively easy path from the spare tire area into the interior cargo area? I would need to pull out my drawers in order to get in and explore and I am hoping to avoid that without the prospects of success.
@1world1love
1) Either through the firewall grommet and under the trim/plastic door sill caps, or under the body along the frame rail.
2) Yes, there is a large grommet on the floor near where the jack is stored.
On either side behind the rear bumper skin there are large-ish oval grommets facing front to back that will get you inside the body mount cavity. You can see these by looking from the rear wheel up towards the rear taillights. There is another round grommet that will get from the body mount cavity to inside the cab pretty much directly below the 3rd row seat release. I am going to run some 2awg from the engine back to the cargo area along the frame rail and up through those grommets.
While digging around trying to access the glove box light, I noticed this little black plastic thing dangling down. What is this? Had a flat side with what looked like worn out foam tape that once secured it somewhere.
Pretty sure it’s the glass break sensor. On my LX it was just taped to the black panel you have lowered there. I believe there is a cutout in the panel for the business end to sit near. The cutout may be underneath the grey mat.
