Spring suggestion?
Philipsburg PA
So this post is a hope for guidance on my suspension. I posted a "2nd guessing post" and it made me realize I made a mistake in my suspension kit that I bought. Thinking back I need to stay off ebay when I'm drinking. I went on to just buy tires and then THIS happened.
Unit:
No iron. Maybe rock sliders in the future but nothing large. Rear hitch mounted spare tire.current 285's, have new 315/75/16 MT and rims to mount. I carry no more than 100lbs of gear and sometimes 2 rear passengers
WANTS:
I want the ride to stay plush and soft. Looking for maybe 2.5"-3" lift. I don't want to change track bars, sway bar drop downs, drive shaft, brake lines ect, ect. Keeping it simple. Springs, shocks, and maybe castor bushings if needed
USE:
Daily driver. 20 miles per week on roads. Rarely over 60mph, no hiways. 20-60 trail miles in maybe a month. It varies but it's off the road about 2-3 times per month. The trails are rocky, bumpy, washed out and muddy. Nothing technical. I pull a camper maybe 10-12 times a year about 30miles from home (i have air lift to install)
SITUATION:
I all ready bought everything. Lmao. I bought rims, tires, 1" wheel spacers
Rancho RS9000xl shocks
OME stabilizer shock
Air lift spring assist (for towing)
Ome 2863J, and 2850J. <--- that is the problem. I used the ome spring chart that shows all the spring wieghts, and lengths. But apparently the springs I bought will net me over 4" of lift, maybe even 5" because im so light. So what would be suggested for springs and shocks?
I only have experience with 3 different spring sets on 80s, so take this with a grain of salt.
'96 LX450: Stock springs with 160k miles and old OEMish shocks, no armor or significant weight. Sagged and was 'floppy'... It seemed very sketchy, especially when going around bumpy curves >30mph.
'96 LX450: OME stock height springs with Bilstein 4600s, no armor or significant weight. About 1-1.5" lift from the old saggy springs. Pretty rigid ride, but could have also been from the E-rated Duratracs. Rode like a 'truck', but felt very stable.
'92 FJ80: TJM 770FR80B/770RR80B 2" lift springs with Bilstein 4600s, TJM T17 bumper w/o winch, no other armor/load. Rides like a damn dream, but I still have P-rated tires on it. I am amazed with how it absorbs bumps and feels very 'planted' and comfortable on road. I'm not sure what the 'actual' lift was over the stock springs.
These TJM springs don't get the pub that the OME springs get, but I'm really impressed with them and would definitely go with them again.
OME 2.5" springs standard rate.
Then you can use those shocks you bought.
In fact, if the seller of your J's doesn't take returns, you could easily trade them here in the classifieds section for the common OME standard springs. Or sell.
@LINUS
What part number is that? Is that the 2863/2850?
I can't recall - the springs are more common referred to in 3 digits here (example 863 / 850 ) - and that's a number I'm sure will hit results here in the internal search engine.
Off the top of my head, I swore that's the part #'s for the 2.5" Heavy rate springs, but I've not had a 2.5" lift / OME springs for 5+ years.
If nothing else, Slee Offroad is still my preferred vendor & Christo knows his stuff (one of the guys who's forgotten more than plenty know -type of fellows).
I can say for fact he can get you exactly the right springs you have use for, and at a competitive price. And he's a good guy with a wealth of knowledge, so he's a heck of a guy to let make a few donuts off you vs some dumb Ebay seller.
He's my go-to when it's a non-OE part I want. Super good guy.
.....and here's where other people drop the name of their favorite vendor, but back a decade ago when @sleeoffroad & @Romer -were the resident guys here back in the now archaic F(z)J80 forum-, the 2 of them got all the spring rate of J's vs. Std 2.5" OME laid out & such. So to me Christo is the resident expert of OME springs, here & in all the 48 continent states.
Anybody recall the part # for 2.5" OME "standard" rate springs? - I would have thought the 850 is FR Heavy / 863 is RR Heavy, but LMK I'm wrong.
Also, if you search @Romer & springs, I bet the thread will pop for you - it's been awhile.
HTH
My $.02
Ditch the 315's and stick to a 2.5"/285 based on your original post and intended use. Medium OME or equilivant from another vendor should do just fine.
Towing with 315's will not do you any favors. 315's will rub without dropping your bump stops. If you want to keep the 315's and not rub, you loose suspension up travel. The 2.5" lift will equal it out, but your not going to add any uptravel without a larger lift. Maybe that is fine depending on your wheeling habits.
At 2.5" you will want caster bushings for proper steering geometry. Can you drive it without? Yes, but for everyone's safety around you please correct the steering.
Personally, a 4" lift is ideal for a 35" tire IMO. But then your in it for the full Monty of brake lines, sway bar drops, caster plates, longer shocks, far pinion correction, and panhard bars maybe a front driveshaft.
For the record I'm currently sitting on Slee 4" spring and 315's. But like most I started stock and progressed through a 2" then 3" before getting to where I am now.
And I also suggest you speak with Slee, Cruiser Outfitters or another reputable Land Cruiser vendor who can work with your specific needs based on actual real word experience. It's not worth saving a couple dollars to get the wrong stuff.
851/860 is the medium setup I believe.
I have mediums I might consider swapping with you. mine are a year old but I've put a lot more weight on the truck recently. I have to check since I park in a garage and I think J's might put me over unless I delete the roof rack
