When adding a 30mm spacer to rear spring...do I have to unbolt shocks or will the axle drop down far enough to pull spring out? Sway bar gets unbolted from what I read.
Thanks
Thanks
So I have given up for this week...even with springs compressed, I could not get them back in with the spacers placed. The axle was dropped as far as possible without breaking the brake fluid line. I tried to articulate the axle with no luck. At 12am I didn't think to just remove the brake line bracket. I finally got it back together without the spacers at 2am so I could leave for work at 5am. Oh well, I'll give it another try next week.
Just remove the bolt that retains the the hard line and the breather and let it flex down. Should be no need for a spring compressor. I have had my rear spring out twice in the last two weeks on my 06 LX. One should be able to remove and install the spacers in under 2 hours alone.![]()
Trust us it will give you enoughGot it. The only thing I didn't do was remove brake line and breather hose brackets. How many more inches will that give? I needed at least 2-3" more for it to work without compressing springs.
Question for yall who have installed the spacers: Do you notice any difference in ride quality?
thanks
AHC absolutely, 30mm dropped my rear 0.7MPa (from 6.4) and front 0.9MPa (from 6.9) which significantly under loaded my front at 6.0MPa. So after backing off TBs four turns I've settled at 6.8 front and 6.1 rear which is damn fine. Before 6.9/6.4, add 30mm gave 6.0/5.7 then rebalance by backing off front four turns bought pressures up to 6.8/6.1.Question for yall who have installed the spacers: Do you notice any difference in ride quality?
thanks
Don't underestimate the extra downforce you'll have to put on the hub. Gravity alone won't be enough to create slack in the spring, even if the other side is on a stand (remember, you removed 60-80 lbs of tire/wheel weight that's normally on the end of the axle when you're out wheeling and see all that droop. You're also doing a little bit of fighting against the twist in the control arm bushings.
1. Unbolt all the bits, and loosen the lugs. Shocks, e-brake, sway bar, etc. Have yet to need to undo the panhard bar in over a dozen times of doing this. (same procedure for spring swap, lift install, air bag install, air bag removal, etc. etc.)
2. Jack up a bit, and remove the tires.
3. jack the rear end up aaaaalllll the way up. As far as you feel safe, or when the roof rack hits the garage door, whichever comes first. Really, you need it way up there so there is sufficient room to droop one side of the axle. I'm always surprised how close to the floor the axle is when the spring comes loose. So forget the safety part, and just ram the roof rack into the open garage door. Then back it off 1/4". Kidding, kinda...
4. Put the 12T jack stands under the frame, just forward of the lower control arm mounts. While the jack still has the axle up, put another jack stand under one side of the axle.
5. Slooowly let the jack down, making sure the stands securely hold the frame and the axle. Check for anything you forgot to loosen...
6. Keep letting the jack down until the low end of the axle dangles.
7. Still likely not enough slack to remove the spring.
8. Do the contortionist thing (if you're 6'4" and working alone), or bribe the wife daughter to help, and put a bunch-o-weight onto the end of the axle with one leg and remove spring at same time. The axle will want to push back. Then it rotates and your foot slips off the studs, whacking you in the shin. Teach your kids new words, then try again... When the axle gets pushed to the bottom, the spring should almost fall out. Without a helper, you may almost have to "bounce" the end of the axle down and tug on the spring at the same time a few times. It's difficult to maintain the constant pressure on the axle by yourself, but can be done. You may have to rotate the spring away from the lower stop a bit to get it past everything, but it's pretty straightforward at that point. Shouldn't be any prybars, etc. needed.
9. Repeat 8 to insert the spring with spacer, only you'll have to kick the axle down oh, say, about 30mm further down. Jack up the axle until there is just enough pressure to hold the spring. Feel up there to make sure spacer is seated properly, and spring seated on spacer.
10. Jack the axle back up to where it was in step 4.
11. Make sure you didn't run the roof rack into the garage door, that rear end needs to be waaaaaayy up there...
12. repeat 5-9 on the other side.
13, make sure to hook everything back up, and you're good - except for the AHC thingy, I don't know nuthin' about that...
