split rims
Pittsburgh
Can I just swap these things out with non split rims or do other alterations need to be made?
Any input would be appreciated.
I guess there is no real reason to swap the split rims out - so long as a cage is used when the tires are changed. Do you know if the sweet shiny hub caps will fit on my widow makers?
Ken
I recently overhauled the axles on a Columbian 40 with the oversized drum brakes. Stock 15” rims will not fit over those drums.
BTW, your carb shipped a couple of hours ago. ;)
Far from widow makers... Toyota split ring (split rims) are known for their reliability and safe function
I have been running them for 20 years
Most of the world uses them
They are NOT the USA semi rig rims that give all split rims a bad name
But will the hub caps fit on them?
Ken
Believe I ran into the same problem years ago. Bought a 63 FJ40 out of a wrecking yard. Did not have a rear axle anymore. Only loose axle I had at the was a early 40 series full floating axle with the monster drums with the cooling fins. Pretty sure the 15" I tried to install were welded. Issue was the wheel would not fit flush against the face of the drum. This cruiser had some 60 series wheels on the front. Those 15" worked.
I have a set of the 16" Toyota split rims. Probably the only thing would run them on is my FJ45LP-B. Much easier using a spare tire winch with large heavy tires than getting them on the back of an FJ40 spare tire carrier. Age and bad back make that challenging.
If your splits do not have hubcap clips... they can be added... but.... if your not the one working on the split rims you should get a set of city racers 16” non split rims that have the clips
Afaik the 16”ers will fit on the large drums
Clips can be added to run factory hub caps. Easier than trying to locate split rims that left the factory with hub caps. Australia never had the 40 series hub caps but split rims were standard for many years.
OMG,! I would not even want to think of trying to lift one of those into a tire carrier, let alone what the weight would do to the carrier over time. Never thought of that!
In Europe we never got hub caps neither but my 74 came with 16" with clips.
If I believe what is listed here, 16" only came with the clips until 01/1976 while 15" was available without before: Disc wheel & wheel cap for Toyota Land Cruiser FJ40LV - Genuine parts So if you look for old trucks/rims it should be possible to find 16" with clips even in countries that did not had the caps.
Mhh never noticed too much of a burden with 7.5*16 tires on them. My father that is over 70 years old frequently changed tires by himself over the years without issues (small trail with a lot of sharp rocks to get home).
