Quick history: Making the best of a 1972 and 1978 FJ40 into one truck. Using the '72 frame because the '78 was toast. I am to the point where I am starting to piece the little things back together for the frame. Looking back I have two different types of splash shields. The top two (in front of the engine/under the radiator) are my main interest/concern -- I believe the '78 is on the right (the passenger side shield below it should also be the '78) because it is more rusty. . .
Is there any functional difference between the two? It seems the '78 sits an inch or so closer to the engine (when one is superimposed over the other with radiator mounting holes line up) and has less metal under the radiator (I think the hole on the '72 is for the radiator drain). If there is no fitment/clearance issue one way or the other I will probably use the '72 as it is more straight/solid.
As far as the passenger side shields go is the '78 shorter due to both (front and rear) brake hard lines existing on the passenger side? I am using the '78 axle with disc brakes and the brake "T" that receives the flexible hose is mounted over the differential towards the passenger side. I would have to drill a new hole to mount the '78 shield on the '72 frame. . . same for the the 90 degree brake line "T" that mounts to the frame. I am thinking of moving the brake line "T" on the axle over to the driver side and using the '72 "path" for the brake hard lines from the master cylinder down to the frame -- does anyone have a suggestion/recommendation as to why this would not be a good idea on a '78 disc brake axle?
Thanks for any help!
Doc
Doc
