Spindle bushing question.
cruiserdan said:
Ali and I have been on the phone trying to decide if it matters where the oil groove in the spindle bushing ends up.
Having looked at several old-style bushings trying to answer this question for a friend, we came to the conclusion that no two were alike, nor did it look like the factory had made any effort to orient the bushing any particular way.
-Spike
I was thinking of replacing my bushings this time around with the repack if they're not too expensive. I've been wondering how much of the birf clicking is due to the stub axle being able to move around when the wheels are turned and the birf is able to move around some in a loose bushing. If nothing else, it would answer that for others if I see no change in the clicking. Wear on the thrust face would also allow even more birf movement. It occured to me on the repacks I've done that it would require knowledge of the original inside diameter and other measurements to know if my bronze bushings are wearing. There's no spec in the FSM is there?
DougM
wile you have everything apart stick the birf in the spindle and see how much the birf moves, I am not aware of any specification from Toyota on this clearance but both my 80 and 62 had only had maybe a 32nd of an inch, that seams ok to me.
if you have a lot of play or if the bushing looks worn/damaged replace it.
Sorry to dig this up....
Got some new OEM spindles today. :D
The new ones are really beautifully machinced. THe faces are even stamped with a cool little "TEQ" symbol. Really adds some authenticity.
With the new spindles, I've noticed right past the bronze bushings there is a roller bearing on the inside. I can assume the added advantage of this as it would center the axle shaft going through the spindle and less wear on the bronze bushing and on the inside of the spindle as well.
My main question is when did Toyota go with the roller bearing just past the bronze bushing and what type of wear would I assume to get?
These units are incredible.
Beno,
Nice part (drool). Those are spendy, too. The roller bearings were spec'd from day one on diesel 80s as I recall. They were not available in the US for a long time but a few years ago Toyota made them available to US dealers. I think today you can still buy the solid bronze bushings as a stand alone part but when you get a complete spindle they all come with the newer roller bearing that's a far better fit and durability improvement.
DougM
So,
You dig up my thread to announce you got new spindles..........from?
:frown:
Beno,
Some pics pls....I've never seen these bad boys.....!
