Installed Mine last weekend. Would of gone super smooth, but I didn't follow the detailed instructions. Hand tight means hand tight! I had one side a little more than hand tight and the other side went fine on the first bolt, but bound up on the second. Yep I cross threaded it! Luckily I have a LOT of experience with this so I was able to stop before I really hosed it. No problem to clean it up with a tap, once I went and got the right size.
After cleaning up the threads and loosening the drivers side to hand tight, the fourth bolt went in easy.
If you follow the directions that come with it it should take you about 1/2hour to install it, 10 min of that is unpacking it!
If you think you know better than the guy that designed the thing, then the install is about 2 hrs, including running into town to get a tap.
The barrier seems really solid. I have a Milford for another vehicle, and the Speski is at least as stout as that if not more. The install is ALOT easier as well!
Thanks Corbet! Keep it up!
Sent from my iPhone using IH8MUD
