has anyone used a speedi sleeve on the parking brake drum?? tell me about it any pictures would be nice
here's a shot of my sexy drum brake and speedi sleeve - it works but it could have been seated a bit lower (in pic). Pic is before I cleaned up the remnants of the flange that is used to pound it down into place (lower edge in pic).
one of the post says to put some permatex on the spline is that after you put the drum on and before the bolt or put on spline before the drum goes on??????????
You are running that parking brake drum?
What did the surface under the sleeve look like?
was there something wrong with the way that was done??????????
yes. there was a slight grove as expected, so hence the sleeve. works great.You are running that parking brake drum?
what groove you looking at? if your "thinking" about the big groove below the sleeve, that's not the contact surface, the contact is up where the sleeve is. As I said in my OP, I hadn't cleaned up the removeable flange yet before the pic was shot. There's a flange on the sleeve that is what is used to pound the sleeve on, then you peel it off of the sleeve after it's seated.There's a tiny groove in it, and it's not quite covered.
