Speedometer
mdjohnsen said:
My speedometer gauges speed well but the mileage doesn't change. Could this be an issue of the gauge or a hook-up somewhere?
My guess is: It's toast
https://forum.ih8mud.com/showthread.php?t=11121&highlight=odometer
Not terribly difficult to loosen up the odo - just takes a little time and some WD-40 to cut through the hardened grease. Just did this to the odo on "Arnold" - no longer stuck at 56999.
If you opt to try this - there is a brass collar between the 1/10th and miles that a bugger to get off the shaft - just be patient and work it w/ a pair if neddle nose pliers. I actually had to put the shaft assy in the vice to get the bushing to move - really a tight fit press fit. And make sure that you keep the parts in order - once the brass bushing is removed it's easy to loose track of your disassembly. I polished the shaft w/ 800 grit wet/dry added a little WD-40 and reassembled.
Harry
Yeah, this applies to the OEM unit only - it really only took me about 45 minutes to get everything cleaned and reassembled.
harry
