Spedo Cable
Seattle, WA
Website
www.bladerunner80.com
Looks like my spedo cable is toast, it was pretty chewed up on the end where it connects to the tranny/transfer case. My cruiser is a 67' with a floor shift 3 speed. Both ends are threaded, I was looking on SOR and they only have cables for 69' on, will this still work on mine? I'm guessing this is a later model 3 speed, aren't the originals a column shift? The PO owner had told me the transmission/transfer case had been upgraded, the shift pattern for the transfer case differs from the diagram on the glove box. Any ideas?
Thanks!
It SHOULD be the same cable. 69 cruisers actually came with a two piece cable with a speedmarker generator that screwed in between the two cables. Sooooo, originally there would have been two cables available, neither of which were long enough!
Virtually NOBODY is still running a speedmarker assembly these days, and most companies, mine included, offer a single cable that spans the length of the run from the speedo head directly to the transfer. Just sent one to IDAVE for his 64; I'm assuming it worked out ok since I haven't heard from him!;p
Hth
Mark A.
mark i have that speedmarker assembly you speek of and have never seen another one, What dose it do and why are there 2 wires coming out of it that go to nothing on the truck?
In my experience, if your speedo head has the metal, and not plastic, receptacle that the cable screws onto, the ONLY source for cruiser parts that sells the correctly threaded cable is Mark's off Road. The SOR cable will not screw into the metal receiver.
THANKS, MARK!
The speedmarker goes to the "computer" attached to the firewall near your clutch pedal. I don't have the speedmarker, but I have a computer if you're interested. :rolleyes: I think it was Texican who posted a picture of one a few months ago.
but what dose it do?
The speedmarker tells the computer what speed you are going, and the computer talks to the VSV which adjusts the distributor/timing via vacuum. It is for the 2 barrel vacuum retard carb/dizzy setup.
It's smog crap! Funnily enough, when Downey started down the EFI road years ago, they were actually thinking of using these as the VSS [vehicle speed sensor] for the EFI computer! I told 'em I thought they were NUTS to use anything that old and THAT OBSCURE, even if I do have a box full of them.;p
The ONLY reason I would use one would be as a poor-mans extension for a 5 speed conversion until I could afford a custom 1-piece cable.
So is the speedmarker/computer the cylinder like object next to the clutch pedal in my 67'? It looks like an overly large capacitor or large D battery or something. It has a couple cut wires hanging out of it. Since, my cruiser has been set up with a 350, I'm guessing thats why its no longer in use. I also thought it might had been the hazard relay, I was rooting around on SOR and found and object that looked similar to what I described and the picture described it was a hazrd relay thingy. Thanks for all the input!
Thanks!
I have a working cable I am about to ditch because I am changing transmissions if you want it for the postage. Screw-on on both ends.
Ed
Thanks, I may have one lined up already though, but I really appreciate it. This website is such a great resource, especially for a noob like myself!
Ed
in case you have no takers, I would be interested ;)
I'll bet Ed's won't fit your speedo head, Claudia.
So..... my speedo cable is squealing like a stuck pig from time to time and the needle is pegging. I disconnected it because I don't want to slam the needle and break it.
I have the speedmarker thingy on the transfer as mentioned above, which being a piece of smog equipment makes sense as the tranny/transfer is a 1979. But I have a 1971 FJ40, and I'm not seeing a computer on the firewall. I think they ran the cable directly to the speedo. I wonder if that's why the PO said the cables failed regularly - they're too tight? Should or can I just get a longer, earlier cable to bypass this mess completely?
