Speakers question
Knoxville, TN
I have read through the threads and have gleamed a lot of info but I have an odd issue.
I have the two speakers in the dash (well under it if you ask me)
I have the two rear door speakers
I have the Cargo area sub/speaker
BUT I don't have the front door speakers on my '93. Am I going crazy ... I see in the threads everyone is talking about replacing those and I want to but there are no speakers there to replace.
Any thoughts?
no camera
Don't have a camera ready right now but the door panel is without holes and no speaker/speaker grill.
Dunno what to do at this point other than possibly cut a hole. I will take a picture tonight and post it up.
Cut a hole in the panel and make it happen. The speakers in the dash are worthless so tap off of those wires and extend them into your door. But obviously make sure you have an opening in the sheet metal for speakers. And get speakers that are very shallow otherwise your window will hit them. Looks like your job will be much tougher then ours was.
in dash speakers
dont discard ur dash speakers, i just finish my sound system yesterday...or almost, i'd cut a hole in the door panel and put a decent 6 1/2 inch speaker in,94 has the door panel already.... replaced it with pioneer premeir 6 1/2's then in the dash i put some alpine type S 4 inch speakers in the dash, and replaced the rear doors with 4 inch alpines as well...its sounds awsome. i did kill the rear compartment area speakers and sub....the rears are like 2 inch crap that suck anyway and my factory was blown. might put in some cb aux speakers there instead....
but dont discard ur dash speak... ur whole front end drivers and passenger side fill with sound, its awsome:banana:
Any thoughts?
Yes, I have some...
My bet is that your Cruiser is an original "Texas" vehicle and as such it is likely to be optioned in a very stupid manner.
You see the distributor for Toyota in Texas is not owned by Toyota (this dates from the early 1960's when Toyota was trying to gain a foothold in the US). This distributor has a habit of ordering weird option combinations and then adding it's own bull-s***, Mickey-Mouse, in-house options.
I suspect you are a victim of that mode of operation.
D-
Don't cut a hole in the factory location where the speaker would normally be. There should be a cutout in the metal behind the door panel, but disregard that hole. It'll only limit you.
Instead remove the lower "pocket." You'll have to remove the door panel and unscrew the pocket from the door panel. When you have the door panel off, you'll notice a much better location at the bottom far edge of the door. You'll also notice that the metal has a cutout there for some reason, possibly for access. But you can use this location (with modification) for a real speaker. One that's not limited to 1.8" or whatever ridiculous depth we're limited to.
There should be another cutout in the metal for the door light. So you can use that for the light that will be taken off of the "pocket."
Dan,
Heh- a "GST" special, eh? I used to deal with both them and SET which is quite well run.
DougM
Dan,
Yup..............
"Let's take the best vehicle line on the planet and see how proficently we can fxxx it up"......:rolleyes:
Yes, I have some...
D-
Yup..............
More evidence to be added to my case for never stepping foot in that state ever again unless absolutely necessary. I hates TX.
Indeed
Yeah I was looking through the paperwork and the dealer imported through Houston, so I have a f'ed up TX vehicle, great :(
So my options are cut a hole where the speaker would normally be on a proper Land Cruiser.
Or remove the lower panel and place the speaker in the "other" spot.
Could I also for that matter pick up some '94 or another year panels?
If this is going to cost me a mini-fortune I think I may just tell the wife to suck it up and deal with the craptacular sound.
thanks
Yes, I have some...
You see the distributor for Toyota in Texas is not owned by Toyota (this dates from the early 1960's when Toyota was trying to gain a foothold in the US). This distributor has a habit of ordering weird option combinations and then adding it's own bull-****, Mickey-Mouse, in-house options.
D-
Nicely put Dan. :D
thanks
I don't see it costing you a fortune, you just have to get creative and choose a location. If you want the standard location you need some slim speakers. I have 5.25 Eclipse speakers but after I did it I found out I could have put 6" and I would totally do that if I were to do it over. Even us with the holes cut out had to do some modifications. I had to drill new hole locations and add spacers so I could use the cool Eclipse grills. So you are just going to have to create some speaker mounting hardware from scrap metal. The costs are going to be in the speakers and Damn does it make a difference even with the stock stereo.
