Build Spdstr280Z's While I'm in There 80 Series Build...
Well, this happened... First start in 2 years and 7 months, after an engine rebuild. I didn't get the actual start, it actually surprised me. I had tried earlier after cranking to build oil pressure, but it didn't fire. I thought I was chasing a no spark issue, but, I guess not....
Exhaust is loud because the O2 sensor port on the Y-pipe is open. The block off plate didn't quite fit, and now I can't find it.
And yep, I took a video in portrait. I'm not very happy with myself either.
On a positive note, like most, I had the wonderful dealer (I think) installed wood trim kit. After all these years, it looked like absolute crap. Peeling it off, I also realized that someone had used CA (super glue) to stick it back down as it tried to peel. Since nothing removes CA that doesn't also melt ABS plastic, I figured I was buying new dash plastic. All of it.... Plus the shifter console.
Before doing that I decided to get a bit cheap creative, and try a different route.
Got to go...
Started with the upper dash piece as a test, really just kind of goofing around with it. Painted using SEM Charcoal Metallic over SEM Sand Free primer. Test came out good enough I decided to clean up some rough edges and finish it...
Charcoal Metallic vs original black...
Came out pretty well, I'm actually really happy with it, Save some money and just a little custom, win - win. Just have to do the rest now.
Jason
This all started when I wrecked my 4Runner.... Does the wife get a Land Cruiser now ?
She hit a deer last week, awaiting the final word from insurance. Pretty bad time to be in the market.
Jason
With the no spark issue solved, a second first start (well, running) video (no, I'm not sure what the piggy grunting noises are, fat guy having an allergy day, IDK), and getting it hot and topping off coolant. Nothing burned, exploded, or gushed out, so I'm pretty happy.
Jason
While I was in there... Noticed the map light / sunroof control surround looked particularly grungy.
IDK what was on that thing, funk, nicotine, years of nastiness came off in sick, brown waves.
Not bad...
Pretty good...
And done...
Even works...
Jason
I'm off work for the rest of the year. and I'm trying to get this thing moving, maybe even literally...
I have been trying to find a trans cooler solution to avoid re-using my old, dirty, crusty, bent fin unit. Even bought a Derale plate and fin cooler that I thought would be an adequate replacement. Derale rates it as for an up to 26,500 pound vehicle. But as I have them side by side to build adapter brackets it just looks puny.... Try to straighten a few more fins and give the old one a rattle can restoration, or go ahead with the Derale ?
Decisions, decisions.
Jason
Jason
Go with the old one but maybe steam clean it before take can? Did wonders on some of my parts.
Jason
Food for thought... the 100 series cooler is available from Dorman. Similar in size to 80 series, you just need a custom bracket. A little CAD and a plasma table could make it easy!!
Got lazy and went with NAPA reman calipers. Hope they hold up. According to the date code they had been on the shelf for a while, hopefully the good rebuilder.
EBC Green Stuff pads...
Rotors are just Brembo replacement blanks.
Jason
Replying to myself here, but I want to add to the "avoid NAPA calipers now" pile on. No problems with those fronts (so far), but the left rear is the latest thing to keep me from driving it finally. Didn't notice it with a quick visual, but it has thread issues as others have reported with the banjo bolt fitting. Factory copper banjo bolts will not torque, tried to be an optimist and try it anyway, of course it leaks. Toyota rears will be here tomorrow. Given the price, I have no idea why I ever got these NAPA calipers anyway.
Jason
Jason
Haven't read you mentioning it in your thread, but I would recommend installing new brake soft lines and banjo bolts while you are at it.
Jason
what torque spec are you using for the banjo bolt?
just went down this road myself over christmas. i just put new Toyota calipers on all four corners. with new banjo bolts and mounting bolts. no issues other than a lighter wallet. already had new-ish slee soft lines.
Good point, all banjo bolts and crush washers are new (and will be another new set for the next round of calipers), and I have Slee stainless lines. I think the frame to axle came with the Slinky kit, and I completed it.
Thanks !
Jason
