Spark plug problem
Working on the wife's 80 today and plan on changing the plugs. After pulling the wires, the rubber end-piece on #6 wire stayed down in the plug well on the plug. This prevents my plug socket from engaging on the plug for removal. Tried several ways to get it out, fabricated tools/hooks but it is still in there. I really don't feel like pulling the valve cover. Anyone have this happen before and have a solution.
Jim
What about a really long and slender pair of needle noise pliers?
What about surgical gauze pliers (sorry dont know the proper name)
Hemostat (sp?)
Something like that is your best bet. I have used them (for this exact job :flipoff2: )
Removing the valve cover will gain you little because the sparkplug tube is attached to the head, not the valve cover.
They do sell a tool for this specific problem, looking on the web there are several variations, hopefully your local auto parts store has one for you... Google "spark plug boot removal tool" or "spark plug boot remover" to see what they look like.
Those tools are for standard type boots. The 80 plugs sit recessed approx. 5" in a tube. The part of the boot I can't get out is cup-shaped, fitting snugly in the tube. It also has a sleeved hole in the cup that the spark plug protrudes through. To top it off, it is cylinder #6 , which is a bitch to reach and work on.
So something like this:
or this:
won't work? I can't recall exactly how much space there is between the boot and the cylindrical wall. Good luck!
The end-cap of the boot fits snugly in the tube. None of these will work. Trying to just destroy it in place now and extract the carnage. That will allow me to remove the last remaining spark plug.
Same thing happened to me. I ended up using a long thin flathead screwdriver to slide behind the spark plug boot and the wall. While I had the screwdriver behind the boot, I sprayed it like crazy with wd40. Then I took a really long needle nose and was able to slip one end behind the boot because of the slickness the wd40 provided.
Warning:
I laid a piece of wood across my engine bay so that it was possible to lay down and be able to stare down the #6 plug hole. Unfortunately, I didn't realize the radiator caps were plastic and ended up cracking the top cap.:doh:
Good luck!
Salue
could you make a hook using a long wire? like thick wire and put a small 90 at the tip to slide along then twist under the end of the remaining boot? just a thought
