Sorting out mufflers
Saratoga Lake, NY
Had a muffler installed by a shop in my area 2-3 weeks ago. Hate it! Too loud!
I'm looking for muffler options for 94-97 80's.
I have found these brand names for the 80-
Bosal
Ansa
flowmaster
flowtech
cheerybomb (vortex)
Walker does not make a muffler for the 80.
How many manufacturers are their for American mufflers and foreign ?
Anyone have a quite muffler installed?
what did you have installed that you hate? That sorta give a starting point.
I've found any brand Turbo is pretty quiet and sounds reasonable.
I had just the muffler replaced. The shop said the replacement was a walker muffler.
Walker doesn't make a replacement muffler for an 80. It sounds like there is a hole somewhere in the exhaust.
I searched many posts looking for a good brand name replacement that would equal the oem sound.
Toyota OEM sells a muffler/tail pipe combo. for around 350-400.
Baktasht, do you sell just the muffler? The one the shop installed must be a "straight through".
It quites down at about 50mph.
I just had my OE muffler replaced due to damage from rocks. I told them I didnt want a "performance" muffler but wanted something quiet like the OE.
They installed a canister OE type muffler which was maybe 10-15% smaller than the original. They were able to mount it up higher to avoid damage.
It is very quiet like the OE. I have no idea what the manufacturer is. I believe the large canister shape results in alot of sound deadening. There arent many vehicles like the LC are large enough to stuff a canister up under the body so most options are smaller, noiser.
While they were at it, I never liked the shape of the tailpipe where it goes over the top of the rear frame rail (right after exiting the muffler). The pipe itself is flattened down from the factory to allow enough room to clear. It wasnt much more to have them bend a new section of pipe to the rear that was bent in full diameter to allow less restrictive exhausting. WIth the SC, I felt it couldnt hurt to allow for better beathing.
It is very queit like the OE. I have no idea what the manufacturer is. I believe the large canister shape results in alot of sound deadening. Most vehicles are large enough to stuff a canister up under the body so most options are smaller, noiser.
While they were at it, i never liked the shape of the tailpipe where it goes over the top of the rear frame rail (right after exiting the muffler). The pipe itself is flattened down from the factory to allow enough room to clear. It wasnt much more to have them bend a new section of pipe to the rear that was bent in full diameter to allow less restrictive exhausting. WIth the SC, I felt it couldnt hurt to allow for better beathing.
How much and where did you get it done at? My exhaust is very loud especially on the highway..
Hope all is well! Its right near the shop here - Mighty Muffler on 7th street. I think it was (sorry, dont remember) a couple hundred at most. Theyve done alot of work for us and always fair priced and good work.
Highway drone is :frown:. A guy here has a Tahoe with a cool sounding muffler. On the way back from Disneyland, the kid in the back threw up from the resonance from the loud highway drone.
I'd rather hear my tunes!
Murf, too bad you don't know who makes that muffler.
I want to go back to the shop and tell them what to replace it with.
Anyone replace theirs with an OEM? If so, what part number? I did a search and found at least 2 numbers and it is a muffler and pipe.
Walking Eagle, which one is the quieter. Quietest even! They can't be all the same sound.
Or is their only 2 real manufacturers for all these mufflers?
That is what I really want to know. Who makes them. The one I have installed the seam is on the bottom. The original OEM had the seam at the top.
I always wondered how that got bent, it's on my list of things to fix
You better drive to high ground! From what I see on TV you guys might get some water soon. :frown:
Haha. That is funny. I'll have to check that place out. Thanks Murf
well a few things the 4.5 twin cam is a bitch to shut up im an exhaust fitted my 80 has extractors and a 3 inch system and i HATE noise ive got 2 straight through 3" mufflers back to back and a resonator in each tail pipe it has twin outlet one either side and it gain about 25to30% more go and 10%saveing on fuel if i dont give it a hard timeon the go pedal .... on the org ? the shop must replace the sub standard muffler that they fitted walker do make that muffler in australia but they should be able to sort it for you if they know what they doing and the tail pipe is squashed cause thay build the chassis and running gear first and thendrop the boby on to it but there is enufroom to fit 3"pipe over the top without and rattling
What?
I had a shop do my exhaust in 2.5" with a Flowmaster 40. Sounds wonderful, and barely any highway drone....unless you're on the throttle a lot. :D
Flowmaster makes different series. I have a 40 series, it's a little loud, but I'm not gonna spend money on another. A 50 series would be quieter than the 40 series, but I don't know if it is quiet enough for you.
I had a Magnaflow in my old 60, that thing rocks!!! It made a difference on the truck, I imagine it would do the same for the 80....:cheers:
magna flow mufflers are great stainless steel and packed with stainless wire nice crisp sound and quiet depending on the length ive use them on 6.0lts chevs and they great
too hard to redo tyhe post so i delted it tryd too answer too many ? at 1 time without the original quotes sorry guys
