- Joined
- Nov 4, 2010
- Threads
- 17
- Messages
- 124
I need a little help here. To start things off ill give you the low down on my situation. I have an 81 pickup but believe the front axle is out of a 79 or 80 (no gussett). The truck came with 5.29's and I decided to change to 4.10's (no problems at all and put 5,000 miles on it that way). Later on I decided to go with 4.56's and an ARB Locker. Things have been fine for the longest part, but here lately I have noticed a slight vibration while in 4wd (with and w/o locker engaged). It is ever so slight so I never worried about it until I changed the fluid in the front axle and noticed ALOT more than normal metal shavings on the plug and fluid. Everything still works as should on the axle and locker. One thing that I want to point out is that everytime we (mechanic and I) changed the gears and such we had to use a puller to get the axle's out of the housing. They didnt go back in that easy either (with both stock and arb diff's). Yes we did have the flats on the birfields lined up. Has anyone had any closely related issues as this. Any help or insight would be greatly appreciated. THanks
