SOLD SOLD - 1991 Toyota Land Cruiser VX-Limited 1HDT Auto HDJ81V w/ Mulgo Pop Top
Status
Not open for further replies.
Tahoe
Year
1991
  1. 80 Series
Incline Village, Nevada 89451 United States
Mileage
139000
Color
Black
Outside Link
https://photos.app.goo.gl/gscsuUHPUboAfnDJA
This beautiful rust-free, right hand drive 1991 Land Cruiser VX-Limited has approximately 224,750 Kilometers (~139k miles) and is equipped with a factory 1HDT turbo-diesel engine, factory locking differentials, an automatic transmission, and a rare integrated Mulgo pop top tent. No expense has been spared, with tens of thousands in restorative mechanical work completed in the last six years. This vehicle is a turn-key build, requiring not much else for extensive overland travel, and it would also make a fantastic daily driver with massaging and heated Scheel-Mann seats. Has a range of nearly 1000 miles, and includes a full spares package.
This HDJ81 was previously owned and built by RGS fellow and Overland Journal podcast host, Matt Scott. During Matt’s ownership, he wrote the following article extolling the 80 Series enduring popularity and usefulness: Why The Land Cruiser 80 Series Is The Next Classic 4WD - Expedition Portal - https://expeditionportal.com/why-the-land-cruiser-80-series-is-the-next-classic-4wd/
Highlights of the build include a G-Turbo, HPD Intercooler, and a turbo-back Beaudesert exhaust. It has a Kaymar dual swing-out bumper, TJM front bumper, with a 24 gallon Long Range Automotive auxiliary tank. It is equipped with a Webasto Diesel Coolant heater to ensure a warm engine at any time with no plug ins required. It has dual batteries, a RedArc isolator and dual voltage gauge, and a Switch Pro 9100 for all accessory wiring.
The Mulgo Pop Top was imported from Australia and installed in Arizona, fully replacing the factory roof. The pop top rises to a very steep angle, and the integrated bed platform pushes up and out of the way, providing a massive amount of headroom, even when standing on the MSA drawers down below. The tall roof provides for a non-claustrophobic sleeping area.
The vehicle was imported from Japan by Land Cruisers Direct and comes with an odometer and crash history certification.
ASKING $34,000
Google Image Gallery: 1991 Toyota Landcruiser HDJ81 - Diesel RHD Poptop · Jul 17, 2024 – Jul 8, 2025 📸 - https://photos.app.goo.gl/gscsuUHPUboAfnDJA
More details and pics below
Highlights:
This vehicle was completely stock in August of 2018 when it was underwent significant preventative maintenance by Land Cruisers Direct where the engine received a full service including a valve adjustment, timing belt, bottom end bearings, a full injector pump and injector rebuild, a new water pump, all new rubber coolant hoses (including to the secondary in-cab heater), a new OEM radiator, a new fan clutch, an US-spec transmission cooler. One of the last remaining OEM Toyota 80 Series Snorkels was installed at the same time.
The brakes were also upgraded to larger NA-spec units, with remanufactured calipers and new rotors. The brake master cylinder was replaced along with all brake lines with extended stainless units. All wheel and axle bearings, axle seals, driveshaft u joints, tie rod ends were also replaced. Knuckles were also rebuilt with OEM parts. Nearly every seal that holds oil has been replaced with an OEM Genuine part.
It is equipped with Scheel-Mann Vario XXL seats with a two stage massage function, covered in a custom grey wool material to match the interior and give a nod to the Japanese who use wool over leather in luxury vehicles. These seats are heated, and wired into OEM heated seat switches in a factory location. This material also breathes well in the heat. Adding to the comfort of the vehicle are two-inch OME HD lift springs and compression adjustable 2.5-inch King Shocks, with remote reservoirs, which are valved specifically for heavier vehicles.
Summit 4X4 Company in Prescott AZ re-geared the vehicle with a 4.56 ratio and installed upgraded chromoly birf joints in the front axle, and heavy-duty Nitro rear axle shafts. This pairs well with the 34-inch tires, while accounting for the diesel engine’s low torque and limited RPM range (which is why we didn’t go with 4.88s). This allows it to drive at modern vehicle speeds on the highway, without causing EGT issues.
The vehicle was originally dark grey, and was painted black in Japan. The paint is fine and has good shine, but shows its age. It looks great until you get very close and start searching, where you will notice evidence of the respray. There are a few scratches around the otherwise straight and rust free body.
The only issues I’ve uncovered are:
  • Windshield washer reservoir leaks and needs to be sealed or replaced.
  • Windshield wiper motor is a bit slower / less power than when new
  • Passenger exterior door handle is a bit loose
Details:
Mulgo Pop Top Tent by Expedition Centre in Australia
Dometic center console refrigerator
Delta metal center console
King Shocks - 2.5-inch remote reservoir with compression adjusters and internal bump stops ($3500)
Custom Scheel-Mann Seats with Massage, Heat - upholstered in custom camira wool ($6000)
OME 2-inch lift springs ($500)
Nitro 4.56 Gears
Nitro Chromoly Rear Axles
Nitro Birfields
5X 285/75-R17 Falken AT3W All Terrain Tires ($1500)
5X SCS F5 Bronze Wheels 17-inch ($1000)
Webasto Thermo-Top C Diesel Heater ($2000 with custom install)
MSA 4X4 Drawer System ($2500)
BlueSea fuse block connected to second battery
HPD Top Mount Intercooler With Fan ($1500)
G-Turbo Grunter Xtreme Turbocharger ($1500)
EGT gauge mounted on dash
Kenwood stereo with integrated rear view camera display
Beaudesert 3.5 Inch Dump Pipe ($500)
Beaudesert Turbo-back 3-inch exhaust ($1500)
Long Range Automotive 24 gallon sub tank with OEM dual filler neck ($2500 installed)
Kaymar Dual Swingout Rear Bumper ($3000 installed and shipped from AU)
TJM front bumper ($750)
Livid Hyperdrive MKII Driving Lights ($750)
Switch Pro SP-9100 ($250 plus install)
Slee HD Tie Rod and Drag Link ($300)
Ironman 4x4 Adjustable Front Panhard Bar ($150)
Delta VS Panhard Relocation Bracket ($150)
Toyota OEM 80 Series Snorkel With 70 V8 Head ($1000 Installed)
Front Recovery Points ($100)
Piles and piles of OEM Toyota spare parts
Factory Locking Differentials (Front, Rear, Center)
Factory Ice Box was removed but is included in spares package
Service and Modification History:
August 2018: Land Cruisers Direct Performed
197,000KM
Timing Belt Change
Front Knuckle Rebuild w/ New Bearings
34” Falken AT3W Tires Installed
SCS F5 17: Wheels Installed
Brand New Toyota Steering Wheel
Heater and Radiator Hoses Replaced and Heater Valve
OEM Tie Rod Ends Replaced
Aisin Fan Clutch and Water Pump
Upgraded Front Brakes from US Spec 80 with reman calipers and rotors
Turbo Drain Pipe
AC Pulley Replaced
Rear Wheel Bearings And Axle Seals
Slee Caster Plates installed
Front Control Arm Bushings replaced with OEM parts
Valve Adjustment
Aisin Brake Master Cylinder Installed
Slee Brake Lines (Frame to Axle and Axle To Caliper)
Injector Pump Rebuild (ACSD Delete, Up-tune 10%)
Injectors Rebuilt
OEM FZJ80 Trans Cooler Installed
EGT Boost Temp Combo Gauge Installed
OEM Genuine Radiator Installed (all new Toyota coolant)
OEM Genuine Snorkel Installed
Webasto Diesel Coolant Engine Heater Installed
Ironman 4X4 adjustable Track bar with OEM type rubber bushings installed
Delta 4X4 Panhard Drop Bracket Installed
12V Starter Conversion, with brand-new uprated Bosch starter
All Driveshaft U Joints Replaced
CDL Wiring inspected and replaced
December 2018: Keith’s Garage Land Cruiser Specialists Performed:
G-Turbo Grunter installation
HPD Australia top mount intercooler with fan installed
Beaudesert Australia turbo back exhaust installed
Replaced all exhaust manifold studs, nuts, gaskets and exhaust bushings with genuine OEM
Replaced all intake seals, nuts, studs, gaskets with genuine OEM
March 2018: Keith’s Garage Land Cruiser Specialists Performed:
Crankshaft Oil Seal (Rear Main Seal) Replaced
Transmission Front Pump Seal Replaced
Transfer Case output and input seals replaced
Transmission Oil Pan Casket and Filter Replaced
30MM Coil Spring spacers installed in rear
OEM Seat Heater switches installed and wired to Scheel-Mann Heated Seats
Mann Provent Diesel Oil Catch Can Installed
Front Sway Bar Bushings Replaced
OEM Genuine Fuel Filter Heater installed
Full Vehicle Alignment
Kaymar Bumper Installation and wired lights
Long Range Australia 24 gallon rear auxiliary tank with in-cab controls installed
Toyota Genuine OEM Dual Tank Filler
ARB HD Rear Springs Installed
120A brand new Bosch alternator installed
AC System inspected and high pressure line replaced
December 2019: Summit 4X4 Company Performed:
Nitro 4.56 Regear with all new bearings
Chromoly Front Birfields
HD Rear Axle Shafts
Additional Modifications
Custom Wool Scheel-Mann Seats with electric lumbar and two massage settings and extended leg slider
Planted Seat Bracket
Switch Pros 9100
Toyota Genuine JDM Spec Auxiliary Fan
Livid Australia Driving Lights
TJM Bumper
Toyota Genuine OEM Radiator Grill
Toyota Genuine OEM Lexus Corner Lights
Toyota Genuine OEM Front Turn Signal Covers
Toyota Genuine OEM Headlight Trim
Toyota Genuine OEM Side Turn Signals
Toyota Genuine OEM Wiper Blades
MSA 4X4 Australia Aluminum Rear Drawer System
Toyota Genuine OEM Jerry Can (which is pretty cool)
Prior owner rebuilt and serviced all window motors, window regulators, and window runs with OEM parts). Windows removed and restored to like-new.
Toyota Genuine OEM Black inner window seal on all windows
Toyota Genuine OEM Black outer window seal and belt moulding around entire vehicle
Toyota Genuine OEM Rear Vent Trim pieces replaced
Toyota Genuine OEM Vacuum Lines
Toyota Genuine OEM Air Filter Box Lid
Toyota Genuine OEM Leather Automatic Transmission Shift Knob
Dash Mat with MSA Organizer
RedArc Dual Battery Isolator & dual battery voltage gauge
Toyota Genuine OEM Airbox Lid Replaced
Dometic Center Console Refrigerator (and realignment of stock aluminum AC tubes due to removal of stock center console ice box)
Delta center console
Sandman Floor Matts
Unbelievable build. Wanna trade?
Status
