Soda blasting
Greenbow, AL
I'm well into a no-holds barred frame off resto of a 1980 FJ40. As I've been thinking about paint stripping I've pretty much come to the conclusion that soda blasting is one of the better alternatives. And as good fortune would have it, a friend has just bought a commercial soda blasting rig!! Initially, he's going to use for a variety of non-automotive paint removal jobs so he's not that familiar with the details of blasting something like my 40 body.
It looks like I might have access to it just for the cost of soda/fuel/beer so l'm looking for any thoughts from folks that have had soda blasting done or know anything about it. I've read the threads dealing with soda blasting. I know soda is not good for rust removal but fortunately I don't have big rust issues.
One of the things I'm most curious about is what happens after a body panel is soda blasted. I've been told that panels will have some degree of rust resistance after blasting (Mountaincruiser's thread seems to suggest the same). I've also been told that panels just need to be washed down with water prior to paint. This all just seems too easy and my brain tells me that a stripped panel, especially one that gets rinsed with water, is at risk of immediate rust.
Also, what about soda blasting the fiberglass top?
Thanks, Ed.
Auburn - not far! I would reccomend putting a coat of self etching primer on anything you get to bare metal quick. Especially here in the south with the humidity. (Right now it is not sooo bad) I does not really matter the media but you will get immediate oxidation that you can not detect on any metal surface that has been blasted no matter the media.
Also, I do not reccomend water for a rinse, but if you do that dry it and go over it right away with a solvent like mineral spirits or laquer thinner to clean and dry the metal.
If you blast something and put water onit you are right, it wil start to rust right away and there is no way to clea the crevises that a blaster gets to.
I don't know much about soda blasting, but I had to give you a quick "War Eagle" 82.
Post some pics.
Soda blasting is the best IMO for paint removal. It will not warp panels like sandblasting. You can sandblast panels with good results, but you have to know what you're doing.
You can actually blast the markings off a coke can with a soda blaster without any distortion or dents. Very gentle.
X2 - but heed the post treatment warning!
Soda will allow you to remove layers of paint and leave the OEM primer if you want. Some say the OEM primer is the best, others say take it down to metal. I read a restore article on a early Bronco. They used soda and just took it down to the primer. Turned out nice.
For paint removal it is fine, but it will not touch rust. They soda blast cars without removing chrome or masking glass.
Ed
