Hello all I am thinking of going SOA, and I was wondering how my current 33s would look underneath a SOA with 3 inch OME
That's what I figured... That means AONTHET month or two of saving! nooooooooooo!!!!
Thanks for the input
different question same same line of thought...
What is a good combination for SOA with 35-37 inch tires?.... springs front and back would be the primary concern? along with spring setup on frame? All the other stuff can be figured from that point..I assume?
What pinion angle is good on the front. Assume "cut and turn" front axle.
So if you had a baseline of 35 to 37 inch tire size for SOA. What springs in the front and what in the rear? What type of mounts for the springs in the frame?
Set aside the question of lockers, steering, brakes, shocks... just focus on the springs and their setup/mounting.
