soa setup
A friend of mine is switching to a dana 60 setup for his fj40 and wants to sell me his SOA setup with front disc brakes. I was just wondering how much would you pay for this?
I think we all would suggest exactly what you are getting.
I for 1 dont know if you need to go SOA if you do not know what high steer is.
High steer alone (which you willl need) can cost $500 new.
So it is very hard to put a price on it. are you just buying axles? Has the front been cut and turned? (which can be different with every rig)
See where we are going with all these questions?
I bought a front axle not too long ago with high steer, mini discs, new hubs, and braided ss brake line....for 100$
i would try and get the driveshafts too.
disc brake front ends sell anywhere from 250$ to 500$ depending on the shape there in. add 50$ for the rear and i would probably pay that if i was in your situation.
i do agree with 89s rule. you will need high steer.
my soa front housing is not cut and turned and does fine. i think that just depends on the truck and how its set up.
Hysteer x2, and the cut-n-turn can vary widely by rig. (how flat the springs are or other conditions) as to wether the cut-n-turn is nessecary and how far you need to turn.:cheers:
There are lost's of variables to consider, it depends on how they are set up. Are the welds on the perches any good? Are they at angles that will work for your set up? Is he swapping them out because they never were right for him? I'd read all the SOA articles in the tech section and then decide if it is something you want to take on, and if you think these axles are worth buying. Two sets of perches from the Dodge dealer only cost me $25 last year. I spent about $500 on a disk brake cruiser that had a hard top and doors. I pulled all that and am selling the rest for six hundred to a guy who wants the tub and a few other things that are intact.
My rough estimates:
$175 front axle
$75 - rear axle
+ $50 for each fine spline diff
+ $50 cut and turn
+$ 0 to $300. hysteer- Really depends on what kit it is.
If you have a welder, I would consider doing your own SOA in the rear. You can get new spring perches for under $20. Reason is that you want to make sure your pinion is pointed correctly or you'll be fighting vibrations. Or you can buy shims and go that route too if you use his axle.
-Dustin
