SOA questions
I have a question if this is to stupid ya'll can delete it. If I am doing a spring over axle conversion and will be using axles that have already been set up for soa what do I need to look into to get steering back to normal?
back to normal? you'll probably need histeer. what do you mean by your using axles already setup for SOA, does this just mean the spring perches have been welded? and/or does the front axle have histeer steering arms on it? are you running stock power steering? 4x4 labs has histeer but you would probably need to buy there tie rods and stuff. other manufacturers' have different histeer setups that would suit you.
do not go back to normal, get hi steer and ps, get rid of push pull crap
Basically I am using some full width axles from a chevy pick up already has the srping perches on the spring what I am wondering if I will need to cut and turn the axles to make up for the steering caster?
You will have plenty more to worry about than caster. You will have to address the axle width, spring perch location, pinion flanges, gearing, steering, side the diff is on, and wheel backspace.
That said, if the axles in question were a D60 front and 14 bolt rear I would do the work to make them fit. :D
yea.. john smith hit it on the nose. your going to need hysteer for the chevy axles. if you don't know even where to start your probably in over your head on this one.
do some research on this, your not the first one to attemp chevy axles under a cruiser, and if the chevy axles were already SOA under a chevy then your going to probably need to outboard your spring hangers front and rear.
I know I am not the first to do it, I have done research on it and have not found this one question answered. Yes I know about he spring perchs, and the gearing I am switching a whole chevy drivetrain under the 40. The only question I can not find an answer is at what point do I need to start worring about the caster angle and if I even need to when making the swap. It is a 60/14bolt transfer and I was looking to find out what information I could find out about before I needed to do the swap.
The "hardcore" section further down the page would be a better place to ask these ?'s
You shouldn't have to worry about the caster on a D60. Most all applications used approximately 8 degrees (+/- 2). You can get a pretty good ideal of where you will be by measuring the angle of the kingpin with the center-section spring perch horizontal. IMO you need to worry more about th epinion angle thatn the caster on a front D60.
