SOA prices
Morro Bay CA
Well i'm looking into doing a SOA but all that it really is holding me back is the good ol GREEN.
So school me on other prices and things you would recommend while all of this
Heres some ball park prices I got
spring over rear,...................................$150
CUT N TURN (and spring over front)..........$500
HI STEER (4x4 labs tr/dl/arms).................$600
new bushings,.....................................$75
u bolts...............................................$130
shackle reversal ..................................$300
extended brake lines...............................$100
extended shocks................................$150-$300
ladder bar...............................$450
anything else recommended by anyone here feel free to say what they knocked out at the same time or even would have done while getting this job done.
(this would all be done by a fab shop. My fab skills are non existant as of right now) :frown:
Thanks,
Joe
I know I can search and seach but I thought that this could be listed in FAQ :grinpimp:
one thing I see of hand is drive shafts. I went double cardain on both source from front mini truck shafts. Can pick them up for $25 a piece and they use the same tube size, so you actually shorten your existing tube to use them. So figure what ever you can buy them for plus the cost to have a shop install them properly if you dont feel comfortable with the alignment.
Power steering if you dont have it is a good thing to add now.
If you build a rear antiwrap bar it should be much less than $450. Regular pipe works fine no need for DOM here, and a shackle plus two of your choice of joint plus maybe a threaded insert. I used a top link from a three point hitch for $27 and it had everything needed as far as joints and threads go.
also I'd figure into the cost an axle rebuild kit cause you might as well while your in there.
Personally, I would forget about doing a shackle reversal,... I know some folks on here like theirs, I personally ran one for approx 2 years, and wasn't impressed. If I had to brake hard, with the sr, my front end would nosedive 4-5 inches, and forget about being comfortable coming down steep inclines. I'd put a front wheel in a hole on a downhill, and feel like the cruiser was going to endo.
Just IMO
WILL
Power Steering (if you don't have it)
Springs (if yours aren't in good shape)
New spring Shackles
TIRES (because now you can handle a bigger size)
Knuckle kit and rebuild (because you are in there anyway)
NEw gear ratio's and lockers (because it is all a part anyway)
Longfields (well it is a part)
Drive Shafts
Seriously though before I went with a 4" lift my research from fab shops was anywhere from 3000 to 5000 dollars in Norhtern. California.
Dave
Just IMO
WILL
Do SR if you wheel, it will keep you from bending springs
Drive shafts $600
shocks $400
spring perches $40
S/R - $250
Springs $500-1000
u-bolts $120
Drive shafts $600
shocks $400
spring perches $40
S/R - $250
Springs $500-1000
u-bolts $120
you might wanna do some shopping around. unless you're gonna run aftermarket new springs, then you should'nt be spending that kind of money on springs. i love the way stockers ride on an soa setup. and they flex great!
you can do the drive shafts for a lot less as well.
there's a lot of good input on this thread. i think you're in the right ball park joe.
if i may offer some advise; build the trac bar out of dom or hrew, not pipe. and buy good ball joints. otheriwse you're gonna end up with a pretzel with busted ends. i can elaborate and post pics to prove this point if needed.....
georg
all the estimates are a bit high for Prices, but thats a good thing.. Your always going to end up spending $2-300 on Random tools/grinding wheels, welding gas, bolts, ect..
i kindof halfassed mine when i did it, and ended up spending $1000..
now im going back and upgrading the things that arent up to par..
here is what i would think for prices
spring over rear,...................................$20 (dodge perches)
CUT N TURN (and spring over front)..........$200 (knuckle rebuild)
HI STEER (4x4 labs tr/dl/arms).................$400-600 (depending on kit)
new bushings,.....................................$50
u bolts............................................. ..$60
shackle reversal ..................................$100 (use old hangers or ruffstuffspecialties)
extended brake lines...............................$50 Braided
extended shocks................................$300 (id go for the 300 Nice ones)
ladder bar...............................$200 Like Georg said build it strong w/good joints..
things your missing
Driveshafts $100-$500 (500 being CV's with a long slip in the front shaft) ($100 being a Square front shaft, and retube the stock rear)
Power Steering $300+ depending on what you do
use your stock springs..
so to me it looks like $2k or so (doing all of the work yourself)
i think isotel is closer in price,
the above mentioned seem a little steep, and the more you can do yourself the cheaper it gets, get proffitts sr kit 50 bucks.
Thanks,
Joe
IMHO it is well worth your time to beg buy or borrow a welder and learn yourself how to do what needs to be done.
I spent a whole lot of money over the years having work done in shops. In those days I had more money than time.
This last round of mods, including a SOA, I did myself. It took a lot longer, and my welds look like bird s***, but I know who to blame when something breaks.
I also saved enough money to do a lot more stuff. Like a Toy box and Longfields.;) Plus I now have the tools and a start on the skills needed to do more cool stuff and my own repairs.
I think mine cost me around $2k and that was including the $300 I spent for a new front axle that was rebuilt and springs. I also had to get new calipers, brake lines, rotors, etc, etc. Lots of new parts basically and it still came in under $3 cause I had a little (whole bunch of) help from my friends.
I did my SOA myself for a fraction of the costs listed but I've been welding forever...
Like Willsta, I too hated SR and now run SOA on stock springs in stock location.
The traction bar is good idea too. Mine made a heck of a difference. I would recommend one on any SOA.
Toy mini double cardans and some schedule 80 make great driveshafts. I've candy cane striped my shafts many times out on the rocks and have yet to damage one...
While you are at it do a rear spring flip and trim the rear fenders. The added wheelbase is well worth the little bit of work involved.
Rusty has the right idea. Buy the right tools with the money and learn to weld...
I'm right in the middle of this exercise, and have learned a lot-like how to weld! If anything, the costs underestimate the actual expenditure if anything. The big ticket items are the same, but the little stuff just keeps coming.
I used mostly 4x4 Labs stuff and very glad I did. My actual build starts on Tuesday since I finally have all the parts and the major pieces. The shackle and spring hangers from Ruffstuff are very nice and I used those as well. For the original poster, you should add in Poly Performance cro-mo rears, and Longfield 30 splines up front, since it will all be apart when you dive in.
You can hack it together for less, but a major mod like this is a chance to do everything right-including stuff like high strength pieces in the appropriate areas.
Dan-Rusty_tlc-I'm wondering how well things fit together with the Toybox. Do you have pics of your rear driveline? Did you extend your wheelbase with 55 or 60 springs? (I am using FJ60 springs) I'm going to use an SM420 + 3speed case, but I would like to use a Toyota 4 speed + toybox + split case in the future, since I have everthing but the Toybox itself. I would like to take a look at your truck at some point. If you have a pic or two, plese send it my way.
things your missing
looks to me that the prices he quted are including shop labor? if so, they are by no means high.
S.O. rear? $20? by welding on dodge pads? you may as well weld a 5/8 bolt onto the housing for a shock mount too. I do belive the quoted pice includes gravel makers pads with shock mounts ans the shop labor for removing the old pads, cleaning up the axle and locating the new ones (setting proper pinion angle)
C&T $200? knuckle rebuild kit, new pads and shock mounts,axle strip down and clean up? OK....
U-Bolts? $60? for all 8? I do belive he was quoted for 8 "REAL" 5/8 u-bolts with nuts and washers. by "real" I mean not that gold rancho, nylock junk.
SR? $100? again, he is paying a profesional to do it! and stock hanger SUCK! . price quoted included gravel makers hangers, shackles and piercing the frame.
EXTEND B-LINES? $50? for all 4 lines? bled? show me a shop that could keep the lights on by charging $50 including material to r&r 4 brake lines ?
LADDER BAR? $200? three 3/4 hiems with inserts and jambs, a length of 1 1/2, the plates on the axle, the shackle, the hardware and a possible crossmember? including labor???? $200?
the prices the poster listed where including materials, labor and consumables. and are by no means high. as a matter of fact,.... I would question the quality of any work being done for less? (by a shop)
OH,.......BTW
how ya guys doin over here :flipoff2:
georg
Oh georg! STFU!!:flipoff2:
4" Ebay TJ coils - $120.00
used TJ coil buckets front & rear top & bottom from Pirate Wanted Section - $90.00
4 lengthened Explorer Procomp shocks $130.00
12 - 3/4" cromo rod ends steering & track bar included - $32.00 each
6 - Flex Joints builder ball assy. - $48.00 each
tool for Flex Joints - $22.00
1 3/4" 1/4" wall DOM - you get your local price
1 1/2" 1/4" wall DOM for draglink & tierod - get your local price
misc. steel & hardware - get your local price
This is all based on a y-link front & 4 link rear setup.
You can go coils & have a *better ride, flex, & lower COG it all depends on your design. Go check out some TJ's suspensions to start planning.......
OH,.......BTW
Ya i'm a dumbass for not saying that this was to be done not by me with the work.
My mistake on that one. Well my cruiser will be in the shop in the next few months just saving and hoping nothing happens in betweed now and when I want it in the shop.
Oh wait damn I blew the clutch on my 4runner the other day............
Ya SH*T happens..
Thanks a lot guys.
Anymore feedback on this is welcome and appreciated greatly too.:)
-Joe
If you had made it up here for the Tree Massacree Of '06 last Sat. you could have seen my truck for yourself.:flipoff2:
To answer the question, it's tight. I have a cute little rear drive shaft. My set up is H42+TB+Orion, stock 40 springs, reversed, with the mil wrap on the wrong end :doh: I have a set of 60 springs that I'll put on someday.
I'll try to remember to take a few pictures of my rear DS and Trac bar for you.
IMHO a trac bar is not optional.
BTW I agree 100% that the small items add up quicker than I expected, just picking up a few #8 bolts an nuts every week came to some serious coin.
At the end of the day I spent almost $100 just to re-fill all my fluids. :eek:
