so where does this link go
Germantown, MD
OK folks, this morning (almost) finished installing my brand spanking new Engine Wiring Harness, boy that was fun! Every thing went in smoothly except this one. I forgot where this (fusible?) link go. I am still searching and looking into the FSM but having a serious brain fart :). I think my brain is now having the CMS (Cylinder Misfiring Syndrome) :D.
I appreciate the tip and hint :cheers:
It actually comes off of the main engine harness through the #4 and #5 intake runners. Hence I just got a new wiring harness. I think it bolts behind the upper air intake, still not sure.
Stole this picture from Slee's tech site.
The red circle is what I am talking about. Welp, just in case if any one has the same amnesia as me while installing a new harness, I thought I'd share my thoughts :). Don't freak out if you can't find a place for these links. They look more like ground strap to me but I can't find a clear picture of these any where in the FSM.
I seem to be in the same boat here.. I know this is an old thread.. But maybe you are still around. I don't ever remember disconnecting this ground strap when removing my intake.. I am guessing it may have connected to one of the bolts holding the upper and lower parts of the intake together and I missed it when taking it apart.. What did you finally figure out? Thanks!
There is a ground strap on the intake like the picture shows. Do you have that?
and take pictures before you tear stuff apart!
Back in 2007, when this thread started you might have to PROCESS pictures at the photo shack at the mall. now, you have no flipping excuse to not whip out your phone and take a dozen pics.
Dont forget to label all the connections too! especially the order of your injectors.
I am not sure I'll have to check when I get the head pulled hopefully this weekend.. I do know that I did not remove the strap from the bolt on the intake like the picture shows.. I just removed the top part of the intake.. I am wondering if the PO used one of those bolts holding the top and bottom together and I did not notice it when removing them.. I just scratched my head after I git the wiring harness pulled from the lower intake and thought I don't remember disconnecting this..
Oh I am taking lots of pics.. However like I said I did not see this one when removing..
@Riad is correct, that is a ground and bolts to the back of the lower intake.
