so my muffler exploded yesterday
Overland Park , Kansas
There are a few guys who run the Bosal muffler. 98 Snake Eater is one of them and he has a thread on the subject. The mounts can be out of alignment every once in a while. I think quality is fair.
Picks of the exploded muffler?
Find Beno. Get the OEM muffler shipped with gaskets for both sides and bolts. Do you need someone near you to install it? His email...
Nalley Toyota Stonecrest
onurazeri1@gmail.com
98SnakeEater is already on his 2nd Bosal. I don't think he's overly impressed with it... granted, he does drive a lot of miles, but I'm not so sure it's a good match for the 80.
I have the walker quiet flow stock replacement muffler on mine. It wasn't perfect, but it bolted in and works fine.
i had a walker on my g35x and it went on perfect. i will check that out and see what beno has. i didnt take pics because it was raining and i didnt want to get wet :) . . the exhaust on it now looks like it might have been replaced more recently than my LX with has 50k less miles on it. i think its factory toyota.
pix tomorrow !
thanks for the fast responses. afterthought: i would consider the EMS if it sounded closer to stock .
i saw some Borla Stainless exhaust too but i worry about the rice factor
Wait he's at Stonecrest now? I thought he was at Lowe.
I have fu Bosal system, the price was right and it works. There is a small leak that has just started to annoy enough, after having it for the past year, that I am gonna take care of.
Snake got 100k out of his, iirc.
If you are looking for a "stock" setup at a good price, I would consider it.
Don't expect a perfect fit, you may have to alter brackets or add gaskets. You will have to remove stickers and plastic from the pipes or your ride will smell like burnt plastic for a while.
In my case I paid 600.00 for the Y-pipe and every piece after it, I am content.
Sent from DynaTAC bag phone
i'm running the bosal , yeah the brackets needed work but bolted up good . I just installed my 2nd one as the 1st one was killed by NJDOT road salt after 9 years . if it was a DD it would have lasted longer . Rockauto.com has it for $113 and change and order bosal hanger #255726 , its not listed for the 1fzjs but the 3f but are the same and $3 each , you do have to source the nuts and washers but thats not a biggie Mine came out of LI so you would see it in a day
Is the Bosal quiet like the OEM, with the OEM resonator tail pipe, or Bosal resonator for those with a cat back Bosal system?
I had a local exhaust guy do mine from the manifold out for $250. It is louder than stock but there is nothing below the frame and it looks great
Possible to get a pic?
I had a Walker on my Avalon DD and it lasted a yr...not doing that again. Got a used ES300 and make it work...it's from a 1993!
So I didn't bother taking a pic , it didnt look as bad as it sounds. The previous owner welded every joint on this exhaust system , so I have no where to bolt in a new muffler. I'm just going to have to buy it and get a muffler shop to cut it in , I'm going to replace from the cat back if I can get away with it.
How much of a pain would it be to just replace the manifold and cats too? I'm just worried I will get this thing cut off and they will tell me I need the exhaust manifold too
Do you need to use NY state approved converters if you replace the originals? I noticed that the converters RockAuto sells state "not approved for CA or NY".
Good question . I guess I better wing it and wait until some one says I have to do it
I just replaced my manifolds and y pipe 2 weeks ago.
Manifolds came off easy enough. The 2 bolts toward the fire wall are a little time consuming. New factory manifolds with gaskets and studs are around $325.
