Snapped Lower Shock Mount Bolt
Columbia, MO
Snapping the rear, lower shock bolts seems to be a fairly common problem in the rust belt. I had PB'd mine for 5 days prior to installing my 30mm MAF spring spacers. DS came out fine but I did snap off the PS bolt. EZ-out also snapped off (:doh:) so I decided to drill it out (Dremel Tungsten bit) and just weld a threaded stud in the remaining cavity. I could have tapped it but did not a have a tap that large so decided to take a different approach. YMMV.
I'm only posting this to create a searchable, possible solution to a broken rear, lower shock mount bolt to help others, not to start any arguments on right/wrong way to fix things. :cheers:
[URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][/URL][/URL][/URL][/URL][/URL][/URL][/URL][/URL]
[URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][/URL][/URL][/URL][/URL][/URL][/URL][/URL][/URL]
[URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][/URL][/URL][/URL][/URL][/URL][/URL][/URL][/URL]
Nice repair!
The band clamp didn't do the trick?
Nice repair!
:p
You know, surprisingly, the clamp held remarkably well for the two days it was on there. I like the new fix better though. I actually know a few people that would have called the clamp a great fix and been very happy with it. :hillbilly:
