Smog pump bracket
Pulley pics:
Will this work?
Poser said:
Pulley pics:
Will this work?
Thanks, I was out at Tim Hill's Parts yard Saturday and measured .96 on a double water pump pulley using a belt. Your photo appears to have the same ball park value.
I also looked at the air pump pulley for an FJ60 and wonder why no one has made an adapter to mount it on a Saginaw pump. It appears to be an ideal candidate with the larger ID centering hole and four mounting screws. One could take a standard press on GM pulley and remove the pulley from the press on flange. Then machine a disk that has a center ID to press on the flange with a step to center the air pump pulley and use a transfer punch to locate the four mounting holes (or 6M threads). Locate the disk in the correct location on the length of the flange. I was intrigued enough that I bought the FJ60 air pump pulley and will see how involved it really is to make. I think that if you use the front crank pulley the air pump pulley will be located on the flange and not behind it over the pump housing. One down side may be the OD of the pulley as it is smaller than the GM or Volvo power steering pulley.
Edit:
I just ordered a steel disk from MSCdirect that is 3.5" in diameter and .5" thick which will fit the pulley mounting diameter. The only machining will be the center press on hole, the centering step and the 4 mounting holes.
bsevans said:
Thanks, I was out at Tim Hill's Parts yard ...
Tim Hill....I really need to get back down there a visit with him again.
Really nice guy.
Post up what you end up making for this pulley adapter.
:beer:
Really nice guy.
:beer:
Don't wait too long as Tim is threatening to retire to his cabin in the White Mountains. I've known Tim for a number of years and have been to his place numerous times. I'm still blown away by the extent of hardware he has and how much he knows. You are right, he is a great person and it is very easy to spend hours talking with him. He teaches me something every time I go out there.
Presently, I'm looking at a design for the FJ60 air pump pulley that has grown to the point that I'm going to try and make a press on adapter hub that will allow one to run either the front or rear crank pulley. I've already converted the air pump on my 78 to use a double pulley utilizing my machined centering spacer and two three bolt air pump pulleys (it looks factory). I know that the FJ60 air pump pulley will work without any problems on the front crank pulley. I need to finish working up the clearances to see if it will clear the pump housing when run on the rear crank pulley. If the clearances will work, the adapter hub will allow one to mount two FJ60 air pump pulleys together for a double power steering pulley setup if needed.
Edit: I measured the diameter of my GM power steering pulley (5.10~") and the FJ60 air pump pulley (4.98~"). There will be little difference in the RPM of the pump shaft.
