smog control module or, thing
SoCal
In stripping off parts to remove & paint body I removed a small black box under the dash, mounted on the firewall pretty close to the clutch pedal. Electrical. Some writing on it (it's out in the garage and I'm just too lazy to go get it ) indicates it's related to smog control system. I'm junking the smog equipment on the engine since it no longer needs to be smogged. Can I do the same with this component?
Vic
Redlands, CA.
Lose it.
Vic
Redlands, CA.
Might want to ask if someone wants it. There's still a lot of cruisers that are subject to Calif. smog law.
Whoa... Hey Abel, I am looking for most of the smog stuff for a "78 Calif spec FJ40, including (especially) the intake/exhaust combo, E.G.R. system (valve, cooler, and plumbing), and air injection pump w/related hardware. Name your price (and we'll deal)!!
Dan
Hey PabloCruise, you are correct, there is a HUGE difference between Cali and the Federales. Abel didn't specify what he has. I have been sniffing around for the Cali emissions stuff for a while. Can't seem to get a lead on the exhaust/intake combo. Any ideas...?
Cali exhaust manifolds are unobtanium - plus w/ the heat from the "catalytic reactor" they warp all to hell. Just change to a Federal intake/exhaust and call it a day - you can continue to run you Cali carb
