I filled up the other day and every time I drive it, I smell fresh inside. I checked all the hoses at the fill neck and under the hood. I see or smell nothing
No it’s on flat ground.Are you parking on an uphill slope? Mine did this when I first got it - it needed a gas cap. Never had an issue since.
Thank you I’ll do that also this afternoon. I’m pretty much going to retighten all clampsThis happens to me after I fill up and make any left hand turns. Need to pull the cargo card and check for leaking lines. Add it to my list.![]()
The clamps on the vapor separator are constant tension clamps, you can't really tighten them. But yes, checking those is a good idea. If it happens right after filling up with fuel, it could be the seal on the filler neck to the body - sometimes the automatic shutoff pumps put in too much fuel and it comes out the top. If that filler neck seal isn't good, the fuel gets inside the body behind the cargo panel and takes a while to evaporate.Thank you I’ll do that also this afternoon. I’m pretty much going to retighten all clamps![]()
Awesome thank you. I’ll check everything I can. The card in the cargo area comes out easy. I’ll remove it next time I fill up and inspect.The clamps on the vapor separator are constant tension clamps, you can't really tighten them. But yes, checking those is a good idea. If it happens right after filling up with fuel, it could be the seal on the filler neck to the body - sometimes the automatic shutoff pumps put in too much fuel and it comes out the top. If that filler neck seal isn't good, the fuel gets inside the body behind the cargo panel and takes a while to evaporate.
Don’t I have to cut a “trap door” to expose the tank sender unit?Fuel tank sender seal leak? It’s in the cargo area under carpet.
From what I’ve heard this is usually the filler tubes as there are several but others can elaborate.
No, there is an access door in the inside cargo floor. A few screws. If you take that off and it’s looks wet it might be your problem. Might just be some loose screws. Easy check and only takes a couple mins.Don’t I have to cut a “trap door” to expose the tank sender unit?
I’ve never had pressure while removing the gas cap. I’ll definitely check it out just to be sure. I’ll look up a replacement for the charcoal canister. I know I’ve read about it here. Thank you for the help.Do you have pressure when you release the gas cap? Could be a gas cap issue or charcoal cannister issue if you don't find anything leaking in the right rear cargo area.
Awesome thank you. I’ll check it out. I’ve never pulled the carpet back to look.No, there is an access door in the inside cargo floor. A few screws. If you take that off and it’s looks wet it might be your problem. Might just be some loose screws. Easy check and only takes a couple mins.
I bet you need a new capI’ve never had pressure while removing the gas cap. I’ll definitely check it out just to be sure. I’ll look up a replacement for the charcoal canister. I know I’ve read about it here. Thank you for the help.
I’ll order one tomorrow. Thank you. Mine doesn’t lock shut.I bet you need a new cap
FJ62 is 77310-12100 $25 at Toyota Parts Deal
