Smashed Differential Drain Plug Surround
Camarillo, CA
Any suggestions on how to repair a smashed differential drain plug surround? Just need to clear enough of the metal away to get a socket on the plug. Was thinking about getting some sort of dremel attachment... However, if someone has another suggestion I'd love to hear it...
It will be easier to work on once the plug is out of the way. You can use a flat chisel to make room, or to knock the plug loose. The Allen head replacement plugs are a permanent solution.
I Also weld a secondary bead on the bung to slow down the ‘intrusion’.
Beat me to the 'punch'.
Cruiser Outfitters
At the end of the ring and pinion section.
Anyone that wheels their cruiser has been through this.
Start with the flat chisel.
It also helps if you grind about an 1/8" of the end off your socket so the socket grips the bolt from the start.
Please elaborate on what the / a " bung" is mark , I assume intrusion is dirt and 4x4 matter from off road ?
The bung is the perimeter ring on the housing, the worn down part that is supposed to protect the drain plug. Welding a bead on the bung makes it taller, helps it keep its shape, and protects the plug. The bead wears off first, just like they do on excavator buckets.
Intrusion, as Mark used it refers to the bung taking a beating and flattening/drifting toward the plug, intruding on its space and preventing easy socket access.
And when the drain plug is removed you get a bung hole. Just thought you'd like to know that.
BigDogg
The Dremel chainsaw sharpening bit is the toughest, funny thing is it’s pink. The other Dremel grinding bits turn to dust on hard steel.
FYI, Dremel also makes a sandpaper flap wheel that is durable and worth purchasing.
