wich is ..
Can Franki share the spring rate .. ?
I was thinking in a pair of bronco coild ( James Duff ) that are close to 22" inches long and 200 - 300 Lb/ft progresive rate ..
that sound perfecto to me .. coz in my case 300lb/ft single rate are definately to much to me ..
I don't know. I should have taken pics comparing the Gen I / II coils. The Gen II coils go to fully compressed winds at the top (meaning you get to way under 200 lb/in in the top winds), but unloaded the fronts were close to same length as my Gen I and delivered an extra inch of lift (my propotype Gen I front coils were shorter than final production). By definition, this is a much higher base spring rate because the fewer "live" winds are creating most of the lift and lift has increased. It handles and drives accordingly.
To more general comments:
The dead winds allow for the required coil length to enable suspension droop when you have a high underlying spring rate. That is the issue with the 80 - in order to get enough load bearing, you need a pretty stiff coil for a lift, but then you can't engineer to downtravel (which you want for max tire size for crawling) in the suspension motion because the stiffer/shorter coil is going to come off the tower and a relevant portion of your suspension travel will be nearly or completely unsprung. Not a good design parameter if your goal is to balance suspension travel in the sweet spot of the spring on all four corners throughout the full range of articulation.
These "dead" winds really aren't dead, they are progressive (although get to a low enough rate to fully compress), and when the suspension cycles to any extension they soften rebound. This entire issue of load bearing vs. coil length is why OME suspensions are biased to up travel in shock design, although as pointed out you can certainly tune OME (which brings to mind lipstick and pigs, but hey that's a personal thing if you want to "save" money by buying 8 different sets of OME coils trying to find one that sits level, handles load properly across a wide range, and does it without a ridiculous jacked up rear end and horrid ride when unloaded
Every other day there is a thread on this forum posted by some poor confused newbie trying to figure out which set of OME coils is going to satisfy all of these conditions, and the only correct answer is
none of them. The good news is that there will be OME coils for sale in the classifieds all the time, and you can change yours out cheaply every few months without evening needing to change out your shocks no matter how much lift you add or subtract
That doesn't mean people aren't happy with OME, nor does it mean that they shouldn't be happy - as has been pointed out there is nothing
wrong with OME, it's not dangerous and you get exactly what you ordered. It does mean that if I blindfolded you and told you that you were either going to be in a mildly modified 100 series or a built 60 on leaf springs, in my rig you'd think you were in the hundred series and on OME you'd think you were on a leaf sprung 60 series. Actually, I think the 60's ride better.
