Show me your rack!!
MoGas
Central Scrutinizer
GOLD Star
Gold Canyon, AZ
Please post up a pic, description, mounting system and size of the roof rack that you have on your 80. Show 'em all.....Big'uns, small'uns, commercially available or home brewed. I wanna see them all.
:cheers:
Dave
wilderness rack 4'6"x5'6"/ 6"T with(6)5"clamps
I just typed out a big reply to another thread like 5 minutes ago, so I'll just copy and paste here :doh:
Before I started building mine, I put a bit of thought into the design...
I looked at all of the available racks as well as some of the homebuilts and started making sketches of what I thought would look good and more importantly, fulfill my needs....
I needed sumthin strong enough for my whole family to walk on, but still be light enough to remove easily...
I wanted the look of a full rack, but with a large opening and unrestricted view from the sunroof...
I also wanted minimal protection for the lights without blocking the actual beams...
After kicking it around in my head for a while, this was my professional paint rendering of the final design ;)
Picked up a set of mounts and started off by making a base platform and fitted it to the rig to make sure everything was level...
Drove it around like that for a few days to test for wind noise, made some adjustments, then pulled it and started adding the rest of the pieces...
Did a little work each day and before I knew it, I had sumthin pretty decent going on :cool:
ConFer 4" mounts
I scored a free old school Con-Ferr roof rack from a friend.
Is that a mailbox? :D
Not yer average mailbox ;)
This is probably a dumb question, but...... What are those cables for the run from the fenders up to the rook rack? What is there purpose?
They're Limb Risers :)
I know that sounds dirty, but they sweep branches over the windshield when wheelin through the bush :cool:
Don't really know the brand. It's old.
Homebrewed Rack with a bunch of 1/4" wall box tube with some old ski rack clamps, which recently broke. Trying to get some stronger ones, looking at the ARB Clamps, because they look cool, and they're ARB, you know?
Some photos:
Click photo for more: (Cleaned up the wires now. Going to put a mesh over lights.)
A bit of planning that went into my rack: A Maya 3D Rendering to scale before building it, really helped! Just didn't think of weight and what metal I had the most of, so the floor of it changed.
What did you use for the long floor pieces?
Sorry about the delay...
I used 2"wide flat stock aluminum 1/8" thick, Cut to length, Same thing on the front and rear hoop, I added some braces on the front for strength
i dont know what brand but i got it for 50 bu:D
48"x54"x8" with quik n easy clamps. i did not remove the factory rack. added the lights and mounted the cb antenna on it. i dont have the spare on top anymore. i bought some toyo mts and its way too heavy to lift up there. with out the cost of the lights im in it for 200 bu.:cheers:
Here is one of La Cabra:
Regards
Alvaro
