Shocks
So I'm curious....I've been tring different shocks to try and get maximum droop with out bottoming out the shock on the compression side....it seems that if I get a shock short enough then it doesn't bottom out but limits my droop...but if it's too long then it bottoms out before the axle reaches the bump stop...how do I fix this.... :confused:
Thanks
Brandon
you need to get taller shock mounts. i've heard alot about people using ford f250 mounts. my friend got some for i think $20, but he's gonna have to trim the inner fender well and move his stock rad. overflow bucket. i'm not sure about the back.
I've heard of people moving the rear shock pin mounts on the rear frame bar inwards to allow for longer shocks. How far is up to you I guess...
This makes the shocks more diagonal and I'm not sure how it affects their dampening ability.
true, i have done his and it has helped. in the front its give and take, unless you get longer shock mounts. its probably better to get more droop than compression.
How far did you move the rear mounts in from their stock location? I'm thinking of doing this mod. Thanks.
you can see in my picks i think, i actually moved the whole mount itself on the rear axle, so i can run shorter and they need not expand or compress a whole lot
