Shifter for 350/350 swapped 72
Alton, IL (near St Louis, MO)
“Rescued” a 72 from a guy a couple years ago and haven’t had the chance to do much with it until now. Has a TH350 transmission but a seriously crappy gear selector. As best I can tell it’s installed properly/adjusted but probably wore out. Anything out there reasonably priced that would work better? Would love to have a column shifter but seeing the price on them certainly excludes me from that option.
Just drive on down to Atlanta, pick this up, and go back to a Toyota manual transmission transmission! :) #easybutton
How long have you been running it? Looks like a clean setup.
At least 25 years with no problems. It's a t-handle. Pull up and back to go into gear. The th350 adapter brings the t-case back a couple inches so I had to modify the cover to move the t-case shifter back a bit. Obviously the B&M shifter can go anywhere as long as the control cable reaches, so I just located it to look normal and be within easy reach.
