When you shift to low range do the shift points change drastically? I have noticed when I shift to low range it is like my truck has a huge stall and one hell of a shift kit. Is this normal?
D
D
Dan actually has a post way back about how to mod the trans control unit to keep the shift points the same in low as in high. Personally, I don't care for the shift pattern in low.
It throws you back in the seat in the 1st to 2nd gear shift.
If you don't need 1st in low (traveling between obstacles etc.), you can press the "2nd Start" button and avoid the annoying jerky shift between 1st and 2nd.
Well, you can if you have a '95+, anyway.
(too lazy to search, but..) surely pulling the plug from the range shifter would do it ? (kinda like a pin 7 mod, plus all the other pins too![]()
That won't work if you pull the whole plugWell I don't necessarily dislike it, I was just curious if it was normal. I have the poor mans CDL switch. Flip it in low range, then pull the diff lock fuse. Voila.One of these days I might buy a CDL switch.
D
