Bomar said:I knew it would not take long to swap out the axles...
You finally got my name right
Changing out all yokes and ujoints to one tons (1350s). More readily available than 1410s if I break the solid spicer one ton ujoints than she will go to 1410s.
Heavy wall front and rear driveshafts being built. All being supplied By Carolina driveline.
Swapping out axles for CUCV Dana 60 / FF 14 bolt courtesy of the secret lair of Mecca after the crawl.
Since we will need to get a locker upfront, we will Eventually go to a 35 spline ARB Locker with chromos, 35 outers.
Blah blah blah
If he does not need the extra angle provided by the 1410 joint then the 1350 will be strong enough.
Blah blah blah
It is only money..
no doubt. I just initially thought I read that 1410 were in it, and got pulled.
She'll hafta be a bounca to break.
Once she gets a taste of that hookdirt...
fj40charles said:What not just go with 1410 ujoints be be done? Highangledriveline.com makes a nice 1410 pinion flange.
http://www.highangledriveline.com/
http://www.highangledriveline.com/Picture_677.jpg
when i swap the axles.
Blah blah blah
