Severe steering problem
Hello everyone-
Just bought a 73 40 this weekend. Problem is that it is all over the road. I have done an extensive search on related problems but wanted to get all opinions possible before I just start replacing parts and racking up bills. It has 4" lift springs with a shackle reversal and 35" tires. Sitting still in my driveway I can turn the wheel damn near a 1/4 turn without any movement of the tires whatsoever. I got underneath and wiggled all components around, I get some back and forth movement at the pass side ball joint so I will replace all of them regardless. Do you think the excessive angle of my drag link would cause the problem or is there too much play in the steering box? Also at around 35-40 the steering wheel jumps back and forth pretty good, without braking. It has castor shims installed, not sure what degree they are but they are 3/8" at forward end. Any help is very appreciated!
Your saginaw conversion does not look like it was done very well so it is no surprise you are experiencing steering issues. Have someone turn the wheel while you observe all joints for slop. Pay close attention to the TREs and center link in particular. The more pronounced your draglink angle the more bumpsteer you may encounter. I don't think that is your issue.
*edit*
You need to have someone who knows what they are doing inspect your steering because between the saginaw conversion and this needing to be moved (first picture) you have safety issues with your steering. I missed this the first time around.
Is this a butt welded joint in the second picture?
if that is a crack circled i would not drive this anywhere, while looking i bet your tre are shot and youll see all sorts of things moving around
Its not a crack, its a weld.....for some reason, and yeah I am sure the TRE's are shot, its all over the road, like scary all over...the PO advertised he could drive 70mph down the road with one hand on the wheel, no fricken way. You don't think the drag link angle is too much?
Is it a continuous weld all the way around the rod that someone used to join two together or is it a tack weld?
I don't think the draglink angle is too much. I ran with an angle almost just like that for years with no issues.
Give us some more info...
Does it steer fine except for the 1/4 turn of slop always present, then you hit a certain speed and all the action starts?
Does the steering always feel vague and does the truck wander and seem darty, especially on a rutted or crowned road?
Like has already been mentioned the Saganaw convertion was done piss poorly! But the main reason for the bad steering characteristics you are experienceing are probobly the shims under the springs. It looks like they were put there to correct the tie rod from hitting the spring, and not for the correct reason which is caster correction.
*edit*
I have some movement in the output shaft on the gearbox so I am getting a new one, the one that s in there now has some numbers written on the side of it so obviously the PO installed a used (bad) one. Also I am trashing the 2 piece draglink for good measure. I think the steering wheel wobble may be a rotor, thats what it feels like anyway...
By moved, I am not sure what you mean, do you happen to have a picture of what it is supposed to look like? I have some movement in the output shaft on the gearbox so I am getting a new one, the one that s in there now has some numbers written on the side of it so obviously the PO installed a used (bad) one. Also I am trashing the 2 piece draglink for good measure.
Definitely ditch the welded two piece rod, that is an accident waiting to happen as is the TRE with the clamp I have pointed out above. Sounds like you are a canidate for a complete steering redo. If you replace all the TREs, the bad rod, and totally redo the saginaw swap your steering issues may resolve themselves. :D Seriously though, I would not drive the thing until you address that steering.
Sounds like slop in the steering box itself to me.
Second changing the tie rod, that it scary.
As for the angle between the relay rod and the tie rod, this will not cause slop in the steering, but bump steer, as has been mentioned. This is involuntary turning of the wheels when you go over an obstacle. I have the same angle in my setup and it is ok.
Good luck.
You PO is a bad man, that rig wasn't driven at 70MPH with one hand on the wheel.
Ditch the welded rod
Get someone to look at the PS conversion in general, it just doesn't look right. (Apart from being on the wrong side of the car for me)
If there are any other welded components then they need changing too.
If this rig was driven for any amount of time with that wobble, chances are most of your steering bits now are worn out and need replacing.
Don't expect a cheap and easy fix.
