I took a picture of the adapter plate close up. Its hard to see since its actually installed, but here it is. The power steering pump, lines, and bracket are all from an FJ62. Simple and bolt on. Since I went with four wheel disk, I installed an FZJ80 brake master cylinder. Years ago my brake booster rusted out and I happened to have the big booster from a 1976. The two work well together but I did have to space the master cylinder out almost 3/8". There just was not that much adjustment on the booster shaft. I naturally run the rear brakes through a adjustable proportioning valve although the rear calipers being almost as large as front makes the proportioning valve adjusted all the way out or close. But it stops. Really well.
Thanks for posting these pics.
I really like your approach to keeping it all Toyota!
I look forward to wheeling Pigs with you one day...
