If the issue are the seized front calipers on a GX470, then this may be a good time to refresh your brakes back to new condition with the oem GX460 calipers, oem GX460 rotors, and some Akebono brake pads.
And from AI:
Why GX470 Calipers Seize More Often
The GX470 (and 4th‑gen 4Runner, and 120‑series Prado) use a 4‑piston fixed caliper design that is notorious for:
• Corrosion forming behind the piston seals
• Pistons sticking in their bores
• Uneven pad wear
• Dragging brakes and overheating
This is a well‑documented issue in GXOR, IH8MUD, and 4Runner forums. Toyota never issued a recall, but the problem is common enough that many GX470 owners replace calipers every 60–100k miles.
The root cause is the piston/seal design and the caliper’s susceptibility to moisture intrusion. Once rust forms behind the dust boots, the pistons no longer retract smoothly.
Why GX460 Calipers Are Less Likely to Seize
When Toyota moved from the GX470 (120‑series) to the GX460 (150‑series), they updated the front brake system:
Larger, thicker rotors
• The GX460 uses a thicker rotor, which requires a larger caliper body.
• This redesign also changed the piston layout and seal geometry.
Improved piston seal design
• Toyota revised the dust boot and seal arrangement to reduce moisture intrusion.
• This is the biggest factor in reducing seizure.
Better corrosion resistance
• The GX460 calipers tend to resist internal rusting better than the GX470 units.
• Many GX460 owners report 150k–200k+ miles on original calipers with no sticking.
Reduced thermal load
• The larger rotor dissipates heat better.
• Lower heat = less seal degradation = fewer stuck pistons.
