Seeking diesel information
In the US very rare as in nonexistent. Australia and other parts of the world had all kinds of them. Canada got a few in 40s, 60s, and 70s.
Most of the 80 series Cruisers had the diesel option in Australia. The 1HZ diesel is 4.2 litre and non-turbo and I believe continued from the 80 to the 100 series. My new 1997 40th Anniversary 80 series has this engine with the 5 speed manual gearbox.
There was also a factory turbo diesel engine in the 80 series (1HDT) as well as a multi-valve turbo diesel engine in the 1996 (?) onwards 80 series (1HDFTE?). The multivalve version (24 valve - 1HDFTE?) is a rare but much sought after engine as it has heaps of 'get up and go'.
Here is a French site that has micro-fiche of most of the Landcruiser engines (left hand side of page, then down a bit!).
http://perso.orange.fr/adherence.4x4/index.htm
PS. The 60 series Cruiser had the 2H 6 cylinder diesel engine and the 12H-T direct injection Turbo diesel engine (this is what is in my 1986 60 series). Both extremely reliable as my 12H-T has travelled over 513000km's and still has plenty of life left!
I believe that Canada may be the best option for those in the US to import a diesel engine. In Australia Landcruisers with diesel engines are quite common.
Here is a Safari Turbo site with a photo that shows an 80 series 1HZ diesel engine with a Safari turbo that will be identical to my car (once my Safari turbo is fitted)."
http://www.airpowersystems.com.au/safari/turbo/1hz_80/80.html
deuce said:
My main goal is to have a diesel fj80. Whether it's factory, or a transplant, doesn't matter much. Just looking for diesel links or sources.
If you want more help, be more specific, what continent are you on? what country? Once we know that, someone may be able to help you better.
I'm in Colorado. My last Toyota was a '85 pickup that I sold in '97. My knowledge of the fj80s is limited, that is why I am seeking knowledge from this site. My wife and I want to replace the 3/4 Suburban with a FJ80, but I would much rather have a diesel than a gas engine. Therefore, I'm seeking sources, links, anything involving diesel FJ80s. I'm not limiting my search to Toyota diesels either. I don't think I want a 5.9 Cummins (okay maybe I would, but not realistically), but a 4cyl. Cummins could be an option. I really don't want to swap out the entire drivetrain. Stock would be fantastic.
Check out the Diesel and 24 volt forums below this forum. There are lots of diesel drivers there - from Canada, UK, Australia... evena few from the US. Alsoa recent and informative thread on an FZJ80 swap with a Toyota 1HD-T (turbodiesel) engine.
M
You are going to pay a premium for a diesel 80 in the US. You might also check www.proffittscruisers.com He's done at least one and I had heard he had 5 in line at one time. He's using the Cummings 4BT. Another engine, which I've researched to death but never tried is the Isuzu 4bd1t. It would make a great transplant in my opinion. Probably the easiest thing to do is find a nice 80 that you like, buy it and convert it (either yourself or pay a professional).
A diesel for your 80 series would be a pick from a 1HZ , 1HDFT and 1HDFTE,
The 1hz is an indirect injection diesel with a rotary injection pump.
The other two are direct injection multi valve motors. The 1hdfte has an electronical controlled injection pump and injectors. Also a Ihdt diesel could be fitted as another guy mentioned.
These pics are of these motors in HZJ75 and 79 utes.:doh:
Thanks for the input, keep it coming. I think I will probably have to go the route of gas FJ80 and convert it.
As for the Isuzu diesel, are you referring to the cabover type chassis trucks? What trans goes behind them?
I have presented a few questions to the guys at Proffitt, just waiting for some responses. Anyone try a Duramax?
I will look into the diesel section more indepth as well.
An engine bay pic of my 1HZ with aftermarket turbo in my HZJ80.
After a little more research, I think I'm leaned toward a 4bt conversion. I may have to figure some ways to quite down the interior though for my wife. She doesn't like the noise that a lot of the Dodge (Cummins) diesels make around here. Of course several have mods that make them louder. I don't mind it, but it would be mostly her daily driver.
I'd appreciate any more pics or links to pics of 80's with non-Toyota diesels.
Again, I'm still learning the Land Cruisers, so don't flame too much. But is the difference between a FJ80 and a FZJ80 just lockers? Since Proffitts is in the same state, I may have to venture over there and pay a visit.
Brave to make your wife drive a 4bt, my buddy just put one in his early 80s Chevy, when ever he drives in to work (fire station) I wonder if the fire engine from the other station is visiting, or if the garbage truck arrived. It is LOUD. Of course the non-mufflered exhaust is a big part, put so is the diesel rattle from the engine. My wife didn't even like the sound of the VW TDI when we test drove it ;)
Check out the newbie guide on Slee Off Road to get a list of the differences between FJ/FZJ. (Most 93-94 and all 95 +) FZJs also have full floater rear axle, 4 wheel disc brakes w/ABS, 16 inch wheels, window tinting, viscous coupling center diff, optional front/rear locking diffs, airbags in 95+...
Research ,because there was a 60 series for sale because his wife wouldnt drive that with a 4BT fitted.
The more I dig, the more I get interested in this diesel bug :D. The Cummins discussion was on few days ago: https://forum.ih8mud.com/showthread.php?t=96454
I might go this route. There is also Duramax with Allison tranny. Basically you have to get whole new engine and drive train. I wish an adapter was available to be able to keep/retain the stock drive train, hopefully some one comes up with one for any diesel engine.
I think that 60 belongs to GreaseCruiser.
There is also a few FritoLay trucks with 4bt's for sale on ebay.
Any updates on the Isuzu or Duramax transplants would be appreciated. I still need to purchase the 80...
would a vw TDI motor work? Theyre easy to come by, but maybe they are a little too small for this application. I know with some mods they are a stout little motor.
