Seeking diesel information
I don't hear good things about VW motors. Others might want to chime in on this. The Isuzu and 4BTA seems to be the most viable options out there. Sounds like there is no adapter out there for 1FZJ (93 and up) tranny and or tcase. I would like to keep my full time 4WD system if I decide on this. I was talking to John at Proffittscruiser, he said an adapter is available for the older model tcase (91 and 92) to mate with the 700R4 tranny but none for the later model trany and or tcase, on 4BT conversions. So as I mentioned in the other thread, I hope some one makes/builds an adapter for easy bolt on solution for any diesel engine. That would make the conversion little easier, you still gotta deal with little electrical kinks here and there among other things.
I have seen some folks consider Mercedes diesels as transplants, but I've never seen one completed.
GM 6.2 and 6.5 diesel V8s work with SBC conversion adapters. But then you have a GM engine, with little benefit if any in fuel mileage.
But yes hang out on the Diesel board as we are always talking about these sorts of things...
Isuzu 135hp, I think the later models are in the 160-175 range. This is my motor of choice. However, they do not seem to be as plentiful for a reasonable price for a swap as the Cummins. Wow the newest models are even more much bigger motor though. Note the tranny and see my notes on the UD motor.
Transmission
-Type 6-Speed Manual MZZ Synchromesh 1st-6th
-Option AISIN 450-43LE Auto 4 Speed Over Drive w/Lock-Up Converter 2nd-4th
Engine
-Type Turbo/Intercooled Diesel/4HK1-TC
-Displacement 5.2 L (317 CID)
-Horsepower (Gross) 190 HP @ 2,600 RPM
-Torque (Gross) 387 lbs./ft. @ 1,500 RPM
A Duramax would be a tough swap. The Allison Transmission would most likely need to be retained and that tranny is huge.
The Chevy 6.2s and 6.5s are not a bad swap for an 80. Mileage isn't the reason people had issues with these motors in trucks, it is power. There is a local guy with a big farm and he uses the 6.5 turbos for all of his running around trucks. They don't have a the big power for towing like a Cummins or Powerstroke but he gets good mileage. I bet he has 20 or so of them in his fleet. I read at Linquip and Brunswick Diesel that you can get in the mid 20 mpgs in a 6.5 powered 80. The real advantage to this swap is you can retain the rest of your drivetrain. http://www.brunswickdiesels.com.au/new/index.php http://www.linquip.com.au/
Nissan (UD) makes a screamer 4Banger with 175hp and it uses an Aisan 450 tranny. I've always wondered how close this was to a A442/A440 in the 91-94 80s. I've never seen one to get measurements. For some reason it seems strange to consider a Nissan powerplant for a Toyota. http://www.udtrucks.com/product/lightguts.htm
Mercedes has a funky bellhousing and I don't think there motors provide enough power for an 80. However, they are fairly cheap and plentiful and there are some places where you can find hot rod information on them. I would say the 300TD motor is one of the top motors in the world in my opinion. Sort of like the 22R line of Toyota. In my opinion that line is probably the best gas 4 cylinder ever made.
Isuzu eingine would be a sweet deal if can be done easily. Yep the newer ones look bigger. I thought this engine can be mate with the GM4080 or 700 tranny. I wish that was the case. But I am not sure if the Australian and/or the Nissan diesels are legal according to the pesky emmission laws around here. You are right, Allison transmission is a HUGE thing, I have seen one in person. I don't know about going that far to fit that. I think the minimum requirement is: if you are doing an engine swap, you have to have the the same year (as your current engine) or newer engine installed. So for a 97, I gotta have at least a 97 diesel. There is 4BTAA which is basically the newer version of the 4BTA, and it is bigger and better. A brand new one cost about $8 ro $10K. Used ones are available in used trucks (mostly). So that might be an option. But the halt point is AGAIN an adapter to fit my tcase :D.
Oh well, I am sure it will come along...
Quote:
Originally Posted by deuce
I would not rule out an adapter for the later fulltime t/c. Anything can be made.
Riad said:
well? who can make it?
I think Marks 4wd in Australia makes an GM to full time 80 t case adapter, but their website is down at the moment.
I am building an adapter for 80 t-cases right now and I am surprised more people don't. It is so much easier to deal with than splitcases. The biggest problem with the 80 so far is the need a different shape fuel tank for more range box options.
