Seat Swap
I purchased the manual seat rails and reclining mechanism (reclining part is not here yet). The seller said they were from a 94 so I guess we'll find out for sure if my seat belt bracket for the female side won't work...
Anyway, on to my question.
It appears the electric seat rail, on one side, is all one piece from rail, up the side. Are there any instructions on how to swap out the rails from an electric to a manual?
I was just under my seat checking this out. As far as I can tell. There is no way to remove the rails from an electric seat without drilling out rivets and cutting welds. I think you could probably swap the base cushion, but the rails and back of the seat are all one unit on the electric.
I saw that there is one bolt holding the reclining part of the electric seat to the back. You have to take the back panel off (two screws and pop off). Then look inside on the rail.
I haven't actually taken that bolt out yet. I'm still trying to imagine the manual parts going on. You can't just take the rails off though, they are welded to the big, black piece of metal that goes all the way into the side of the seat (which is attached by the bolt I am talking about). There is another bolt under the plastic cover on the side. So The rails can come off but only like you say, a bunch of other stuff has to come with them.
Well, I dug into mine a little more. I thought for sure you were right but...I have the manual rails on with no drilling, welding, grinding or cursing. There are a couple of holes I'll have to drill but I won't need to tap them and so far all is going well. Again, I don't have the manual reclining part of the seats yet so that would be another part of the story.
I'll post up a thread with pics when I'm done.
I went and picked up the manual reclining mechanisms today. Well, the guy just gave me the rest of the seats; I now have all of the manual seats.
So I looked things over and determined how the reclining portion would go onto my electric seats. This is where the process took a big dump. Let me explain what worked and what didn't.
So, the rail that goes on the seat belt latch side fits fine. That seat rail would bolt right in and would move all but the last notch and then it hits the mounting bracket for the electric motors. The manual reclining bracket that runs up the side of the backrest would fit on both sides of the backrest and the bolt holes on the backrests would be fine.
The front hole of the non-seat belt latch rail would attach but there are some things that would have to be done to help everything else fit. Also, on the side of the seat base, one of the bolt holes of the manual reclining mechanism line up but it has two holes (more on that in a minute).
So what didn't work?
The rail on the non-seat belt latch side. There are several problems with this side. First, toward the rear, there is no bolt hole on the electric seat frame for the bolt on the rear of the rail; it would be in limbo. The manual seat lever has to "live" in the half-hole in the bracket that used to hold the electric seat motors.
Since it has to live in the half-hole in the electric motor mount, when I tighten down the front bolt, it causes the manual seat lever to hit the bottom of the bracket and front of the seat. At that point you can't move the seat because the lever is jammed.
The second bolt hole on the reclining seat mechanism has nothing to attach to like it does on the manual seat base. In fact, just eye-balling it, I believe the second hole would actually protrude beyond the back of the electric seat base.
So, the final assessment is: It could work if you had the time to make a bracket to attach the rear, non-seat belt latch rail so it is not in limbo. That bracket would have to wrap around and down to bolt in on the side. You'd also have to make a bracket to extend a little bit beyong the rear of the seat to accomodate the second bolt of the reclining mechanism that protrudes beyond the seat.
Prior to taking out the electric wiring of the electric seat you'd have to adjust the seat height motors all the way down. You'd have to put in some stand-offs between the seat frame and the seat mounting holes to get the seat high enough and away from the electric seat frame to allow the manual lever to operate once things were tightened down. You would also have to drill two holes in each seat rail to accomodate the three bolts (like in the electric seat) on the front of each rail.
That's a lot of work.
Or, you could just swap in the whole manual seat. The seats would sit lower but you could get new cushions to make you sit higher. Or put some stand-offs in the manual seats between the rails and the seat to make it sit higher.
I won't be swapping or fiddling with this anymore (unless I come up with some other great solution). I probably wont swap the whole seat because the manuals seats are brown cloth and I have grey leather.
Anyone interested in some brown cloth manual seats?
I need some manual seats
Alternative seats?
I have long wanted to find replacement seats for the 80 and now they are getting tattered to the point that I might as well start looking. I'm 6'03" so the leg room is only adequate, but the height is what I really don't care for. I read another post that stated, "I feel like I'm riding on a booster seat", which in turn really sums it up. I'm looking for a "low slung" replacement seat and have kinda been researching Volvo seats. Making a bracket isn't an issue, just wondering if anybody has any suggestions of what has worked in the past.
I don't think anything has really "worked" in the past aside from manual cloth seats. Corbeau makes a bracket but the one thread I found made that setup sound not very good. I just can't believe Metal Tech or some one like that doesn't make some good brackets for seats. They make them for the FJ Cruiser but how many people swap perfectly good newish seats for aftermarket? 90% of the FJ80's on the road could use new seats due to age and wear.
