seat brackets from landtank
Carpinteria, CA
I just got my seat brackets from landtank today(thanks Rick). the install instructions look great and easy to follow. Can anybody give me an idea on how much time i should set aside for this install or any helpful advice before i start?
Thanks
It took me about 5 hours on the first seat and 3 on the second. First seat I went very slow and often cross referenced the instructions, pictures, and forum feedback on previous installs. Make sure you have a good sharp 1/4 metal drill bit and a metal countersink. A bench grinder would also be very helpful with the rails. I had to do everything with a dremel and a 12V rechargeable drill or the second seat would have only takem about two hours.
done
ok,
i just finished installing my seat brackets. it went well for the most part. getting the bearing put back into the right place was a little tricky and i had a little trouble with the hole allignment on the brackets themselves. but all things considered it went good. the instructions are well put together and pretty easy to understand. i read them 3 or 4 times before picking up a wrench, im sure that helped in the long run. it took me almost 3 hours maybe 2 1/2 but whose counting with results like this. this is by far the best mod a tall guy can make. i found that im not even needing all of the room. i am very pleased with the end result!
THANKS LANDTANK
what is the best tool for grinding that needs to be done? Dremel or a actual grinder?
For me the first time, driver's side took a touch over three hours. The passenger side was around 30 mins. This is one of those projects that you need to learn and alleviate fears on one seat before you crank thru the other seat. In hindsight I should have done the passenger seat first just for the flexibility of needing to use the truck.
Thanks!
Does everyone do the passenger side? I was just going to skip that side. (Other people options)
Did my kit include both seats? Are they interchangeable
when trimming down the side of the rail at the front you can use a hacksaw instead or grinding it off. The last time I installed a set I think it was around 3 hours with me taking the pictures that are now in the install pdf, that was for two seats.
Three hours is the same amount of time the dealership charges.
Got this done this weekend. Wow.. i never believed it would give me this much room. I dont even have it all the way back. I am about 5' 10" Awesome.
I have to admit i didnt look at all you had to do to complete this before i purchased the kit. It was a little confusing at first, but once i got it then it was an easy project.
Thank you for quality product.
