I tried to set it up for SC but not sure If I did it right SG instructions werent all that hepful.It is 'Engine Loading' or a percentage of the maximum power available 'currently being generated'.
So...IF you have calibrated the ScanGauge it might be useful information on a S/C unit.
Probably worthless on non S/C since they just don't make a lot of power anyway.
so 24 is the percentage being used??
That spot is so much better than where i have mine mounted... Definitely putting it there
Yep, with a single DIN head unit...you can have a Cubby Hole that is just the perfect size for a ScanGauge.
It's where the ham radio goes. CB radios are the 8 track tapes of comms.But that's where the CB radio goes...
I've also seen folks mount small CB's in the ashtray opening (with very slight mods
But that's where the ham radio goes...
Dang....! Well then what goes in the cup holder?
BEER!!
I have a double scanguage goes right where ashtray isnt cb is all in one no box needed.Yep, with a single DIN head unit...you can have a Cubby Hole that is just the perfect size for a ScanGauge.
