Thinking to mount mine high on trans tunnel (upslope on shifter console), using cutout and duplicate OBD II port to be wired behind dash or under trans tunnel/shifter console (so I can keep the fuse cover on). Thought I once saw someone use this location, don't recall whether they installed dupe OBD II port as well.
Would appreciate any pix/info on installing in this location OR wiring up new OBD II port. In the meantime, here are the threads I've found (feel free to link any others you may find)...
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
Installed ScanGauge in ashtray slot...
Greetings. 1995 FZJ80. Tonight I finished up my ScanGauge install. I'm very glad I went with a ScanGauge vice a WiFi or Bluetooth setup. It's great knowing these important parameters are hard wired and the device will shut off properly. Installing it in the ashtray slot was a little tricky, but...
forum.ih8mud.com
Scan Gauge II Install - '97 FZJ80
Just thought I would share my ScanGauge II installation, using a modified version of Gone Bush Expeditions Gone Bush Expeditions- Follow Us- Official Blog- Overlanding, Off-Roading, Caravanning, Backpacking, Bushcrafting The original intent was to install exactly as was done in the above link...
forum.ih8mud.com
forum.ih8mud.com
Scanguage mount question
forum.ih8mud.com
forum.ih8mud.com
Difinitive Answer: BlendMount Compatibility with ScanGauge 2
forum.ih8mud.com
My Scangauge mounting
I wanted to keep the OBD port available for service, so I hacked the fuse box cover (relocated the fuse diagram to the owner's manual). Ran the wiring behind the plastic and mounted the gauge below the rear heater switch with velcro. Wire comes up between the shifter console and the dash. I...
forum.ih8mud.com
