Has anyone here used the "blendmount" for their Scanguage II? It looks like a cleaner install than just sticking it near my shifter. I wanted to know if it mated up with the mirror well, and if it allowed for a more secure mount than the provided double stick tape. Also, I'd assume that headliner removal would be required for the cleanest install (if so, I'll do dynamat/equivalent while I'm at it).
I'm too broke right now to drop 40 on the fancy mount. But my planned permanent solution (below) might be worth considering.
I stuck mine right behind the wheel on the plastic cover. Found it blocked my view of the blue hi beam warning light. I lifted it and moved it to the right about an inch. Unblocked the view of that light, but I know there are other hiding back there. Works well enough where it is for right now.
Am thinking of making a little angled mount for the lower left corner of the Dash to slip between the bezel trim and the dash trim. There sorta a flat spot there, but not enough without adding more. I have the Scan Gauge E, so it's a little smaller and easier to place. I wouldn't leave home without now. Best of all, no codes have returned since I cleared the ones that were making the CEL come on, which is why I bought it.
