SC vs Gears
Huntsville, Alabama
The usual disclaimer... blah blah blah . Yes I've searched. No luck. My question/situation is that I've got my truck up a bit and the 315s go on this week. The next must do is a gear swap or ( wait for it, wait for it ) Supercharger. If I go the S/C route is a gear change still necessary? Is there any benefit to go this direction as opposed to the more conventional solution of changing the gearing? From what I have been able to find in the threads dealing with the S/C the install is straight forward its the intercooler that needs to be shop built and pieced together. I guess dollars need to be looked at as well. The S/C is $ 3000 + (but I would feel more comfortable intalling it that trying to set-up the back lash on a diff.) so just from a numbers stand point the gears look less expensive ( even having someone install and setting them up ). What type of stress is a S/C going to put on an older motor (270k), Would a re-build be necessary before bolting one on. The p/o had the HG done at 170K by the lexus dealer but other than that nothing but oil changes and routine maintaince .... Well you get the general idea and the direction I am headed. What are your thoughts and experiences.
I would spend money on gears and upgrading axles and birfs for the money. i thought of doing supercharging but you still need to take care of the gearing down the line anyway. i was looking at a supercharger and it fell through and i spent the money on gears, longfields superset for the front, and poly performance chromoly rear axle shafts. I am glad i did.
270K is kind of high even for the 1FZ. The S/C definitely adds some stress to the motor. I've had mine on for ~7K miles so far and have not had any problems (knock on wood) and I have not needed an intercooler. It really does change the feel of the truck, it's still a fat lumbering tank, but definitely has some more pep to it. You should also consider the transmission stress. I have had a couple of hints over the past few months that have led me to believe that my transmission might be slipping every once in a while. However, for a bolt on, out of the box solution, a S/C isn't a bad option.
I'm still running stock gears and I don't seem to have any problems, even when going up mountain grades out west. I probably will only re-gear if I step up to 37's and I definitely do not see that happening for at least 5 years.
If my 1FZ ever hits the crapper I might consider doing an engine swap with something that gets better fuel economy and more power like the newer Tundra V8 motor. 4 months after I bought my 80 I thought that I had a HG leak even though the PO had already paid the lexus dealer to replace the original HG. It turns out that I just had a leaky coolant line. But at the time I was strongly considering an engine swap instead of fixing the HG which I thought was blown.
With as many miles as you have I'd probably vote for lower gears. They would probably buy you more miles out of your motor and leave you with more engine options if your 1FZ ever takes a dive.
Good to hear, it like you were able to get a refund.
Did you consider a part time kit? I've heard that longfields wear quickly on daily drivers. Nevermind if your 80 isn't a DD.
Gears will give you benefits in offroad situations that the supercharger can't. (I don't care what Sumo says :flipoff2:). Gears will also lower the stress on your engine and drivetrain, while the supercharger will only increase it. I'm sure the supercharger will net you more performance gain on the street though, so it depends on what you want.
I would be nervous about installing a SC on an engine with that many miles, unless I did as part of an engine rebuild.
I would bore out the piston holes abit and go for even greater power
I have both gears and the supercharger
The supercharger is more for on road and towing over mtn passes. The gears really help off road.
The supercharger allows me to speed up quick on on highway on ramps and accelerate quicker on the highway when I want to pass. Not to much on street roads.
The gears do help a bit on road in general, but going slow crawling up a rock, or going down hill and letting the gears slow me down (more engine brake) instead of the brake is where they shine.
gears made a noticable difference offroad. They add a bit more pep onroad, the tradeoff is a higher rpm at freeway cruising.
If you don't wheel much, the SC might be more fun for your $.
If you wheel, the gears are worth it.
supercharger= road machine
gears = offroad machine
which machine do you want?
--of course there are exceptions to the rules, rules always have exceptions, but if you drive 75% of your hours on the highway, SC is the clear answer. If you drive 75% of your time on trails, gears are a clear winner---
Unless you tow, then gears should come first. That sweet spot between 2700- 3200 rpms is much easier to hit with the right gears. Adding 315's to stock gears essentially makes 3rd gear your overdrive when towing, and it's a big drop in speed from 3rd to 2nd. The second I drop below 2600 rpms on a grade, I'm into second gear and 4000 rpms to keep speed. Gears will fix that.
I run both as well and also feel gears should come first for you although I feel the gears help me on road as much as off road. Better towing, up to speed capability, cruising at freeway speeds, passing traffic, etc.
as for the difficulty involved: you can buy someone else's 3rds for pretty reasonable rates, and send them off to a qualified tech to set up. Search a little, there is a name that will come up again and again, with more positive feedback than you can imagine. I've never used Zuk's services, so I won't endorse them, but if I lived within UPS distance of him, I'd seriously consider that route.
Anyway- if you can't tolerate downtime, using a 'spare' set of 3rd members will get you where you need to be. Installing the 3rd into the axle is simple.
Then you can sell your 3rds if you don't want the trail spares, and the cycle can continue.
One advantage of the dropout 3rd/full float axles is they can be run without the diff. Pull one, run the rig 2wd, once that one is done repeat for the other diff. It can be done without spare diffs and still have DD use of the rig.
