saginaw box
went hunting yesterday and foung a heap camanchee maybe early 80's.power steering box was on the inside frame rail. the guy said it was a saginaw .will this work.
The early 80's saginaw are usually the 3.5 turn lock to lock, it will work but it's a little quick on the highway especially with larger tires, Larry
Interestingly, there are a TON of vehicles that run a "Saginaw" box, including Jeeps, Scouts, Chevs, and more....
Check the PS links in the cruisertech stuff, and be specific about what box you are looking for....my poor memory says it's a 73ish Impala...
Mine is a Scout...which is also a Saginaw....
im sure it will work, might not be what you want but you can make it work. you will love power steering. priceless
2.5 or 3.5
I had a 2.5 on mine for a week or so until it started leaking. Off a Camaro.
Not it's got a 3.5 turn on it from a 92 Chevy Pickup.
Can't really tell the difference between at 60 mph.
It's what you get used to.
2.5 is manageable, no matter what everybody says.
39.5" tsl/boggers. Unbalanced, missing chunks the size of golf balls.
Beadlocks, unknown tire pressure.
Runs good until 60 mph. Then the rig starts vibrating so bad you can't see.
J.R.
