RV Tow Question
Florida
I opened a thread here but not getting reply.
Size Matters for towing
What models are some of you hauling? Weight? Length? Slide out? What can i safely tow to North Carolina mountains?
Im trying really hard to stay at around 3500 lbs towing weight but with 2 adults, 2 kids and dog, we need the room and anything we looked at small wise is just too small for all of us to fit. We need bunk beds for the kids and that puts us out of the 3500 lbs weight class and int 4500 lbs+. I also want dual axle in case of blow out. That is really a big issue with me...i cringe of a blow out with only single axle.
Good luck. I'd downsize tires or re-gear, even towing 4k lbs. I'm sure someone will disagree, but my 98 LX on 285's can hardly get out of it's own way accelerating to highway speeds.
There are 3500lb bunkhouse trailers. I had a Spree Escape 19bh. Something in the "Lite" and foam wall category will likely be 20' and weigh sub- 4k lbs.
I tow an Rpod 180 with my 2002 LX480. Tows fine from central N.C to S.C. beaches. Mostly flat to moderate inclines. I've towed it all the way with Overdrive Off, and I've towed all the way with OD on but switched off for inclines. Have not yet taken it to Mountains. Its approx 3,000 lbs loaded with gear.
I towed my Jayco 19' hybrid X19H all over the place with my 03 LX470 and 33" tires last summer from Oregon to Colorado. The Jayco weighs 3600lb dry, 5000lb max.
It won't win any speed contests or mileage contests, but it pulled it just fine. Just keep the RPM's up when you're pulling up hills.
Cool! So i have options for under 4000 lbs. This is great news. We just started looking this weekend. How do you feel about single axle? Any issues? Also worried about fish tailing.
The main issue I see with single axle is carrying capacity. You're likely going to have a 3500lb capacity axle with a 3000lb dry trailer. Add water/propane/batteries, and you're left with about 200 to maybe 300lbs for food/gear/clothing. You have to be very careful about what you pack.
With a dual axle you generally have close to 1400lbs carrying capacity with a 3600lb trailer.
The other issue is if you have a blowout with a single axle, it can be really bad. If you have a blow out with dual axles it's scary but you still have some rubber on the ground.
^^^^ Regardless what you end up choosing, first thing to do is ditch the 'trailer' tires that come on the unit and replace with LT tires. Air them up to their maximum pressure and don't exceed 65 mph (60 would be better).
30 years in the RV business and the number 1 issue/repair is from Blow-Outs...hands down. IF you are lucky...the tire will just take out the fender skirt and your J-Wrap panel. But I've seen tires 'hang on' and act like a big Weed Eater inside the fender well. Literally taking out the floor and anything above it (wiring, plumbing, bottom of cabinets, etc..).
Generally....if you have a good sway control device a blow-out (even on single axle trailers) will not send you fish tailing all over the road (though it IS possible). Usually....you will be aware of the issue and can come to a slow and controlled stop.
Of course, expect wheel damage and possible replacement of the wheel as well. So...the object is to NOT HAVE a blow-out at all. One, two or three axles! Nearly all tires that come on new trailers are JUNK. They are the cheapest thing the manufacturer could find and quickly get worse with age. Then folks over-load their RV's, under-inflate the tires, run them at 70+ mph on HOT pavement and the inevitable happens.
Lastly: IF you plan to keep your RV for more than a few years and USE it several times a year. Buy the extended warranty. I can pretty much guarantee you...it will pay for itself and more.
Wait wait wait...you mean just because I have a Dodge 3/4 ton with a Cummin's and dual stacks through the floor of the truck bed and a 6" lift with 35" tires I can't tow my trailer at 80mph in August in Phoenix? ;)
I see it all the time, and it makes me cringe. I am being heavily sarcastic here, do not tow any trailer like that please no matter what your tow rig is.
I did see a guy doing this exact same thing towing a speed boat, trailer blew a tire, boat ended up in the median, the trailer tounge was twisted and bent and the boat had hit a car and ran him off the road.
Very nice set up! We are looking to do something very similar in the next couple of years with our 03 LX470. Did you do any modifications to your suspension/AHC?
I see you have a 2001 LC (4-speed). We used to tow a 3,500 lb max pop-up with our 2000 LX. I thought that was about the limit. Especially with 4 occupants and their luggage. Maybe the 2002 and up models (5-speed) are better suited for heavier trailers?
I've hauled 5,500 to 6,000 lb locally, but would never do that for longer distances.
Thanks. I have had the AHC deleted and have a 2” OME medium kit.
I use a weight distribution hitch which keeps the vehicle level. I imagine using the WD hitch would work well with the AHC.
My 2002 LX, 4-speed, pulls our Rpod very well.
Sometimes on the Interstate I find my speed creeps 70-75mph without me realizing it.
It does feel comfortable at that speed but I back it off to 60-65mph.
I do have a WDH with Sway Control, AND I do check Air Pressure at 50psi and the lug nuts torqued to 100 lb-ft.
I really wanted a larger 8'wide 4,000 lb dry trailer but settled on the Rpod.
Nice thing about the Rpod is its narrower and does not require towing mirrors.
In addition, I found an Excel Worksheet that you can plug in weights of everything
from fuel, passengers weight (if you can get your wife to tell you her weight), cargo,
weight of hitch, etc. to discern if you are within the limits of your vehicle. I found that
the 4,000 lb trailer maxed the towing capacity of our LX470's.
First thing to do is ditch the 'trailer' tires that come on the unit and replace with LT tires. Air them up to their maximum pressure and don't exceed 65 mph (60 would be better).
Just be aware that in many jurisdictions it is illegal to run LT tires on trailers. ST is the only “legal” option. I would check the laws where you live, and where you plan to travel to. It’s unlikely at best that you’d ever get checked, but it’s good to know where you stand.
Extended warranty is totally worth it. RVs are built like crap for the most part, so do your research and as much as you shop for weight, shop for quality too. Unfortunately those two factors will usually be at odds with each other.
I once towed my 31’ Airstream loaded with an extra 1000-1200 lbs in the trailer, and 600-800 in the LX for a few hundred miles back when I had a LX450. This was in the mountains too. Not something I’d ever do because I WANT to, but it shows how strong these Land Cruisers are.
Great feedback! @flintknapper do you sell RV's? Or can recommend someone?
No I am retired. I spent a bunch of years in the engineering dept. of a high end manufacturer of Class A Motorhomes, but also have experience with other RV's (tow behind trailers, from 12' to 42').
Pretty much seen it all when it comes to mishaps with Motorhomes or RV Trailers.
"Just be aware that in many jurisdictions it is illegal to run LT tires on trailers. ST is the only “legal” option."
What is the reasoning for this?
I tow an R-Pod (2600 Dry) with my Tacoma, and definitely replace your tires with the highest load LT tire you can fit. I've seen the internet folklore about some jurisdictions not allowing LT tires on trailers, but I've never seen anyone post a link to an actual law on such. On our first trip, we blew both of the original tires that were 3 years old. After that I upgraded to LT Tires and feel much more confident. I'm thinking of adding a 7 pin and brake controller to the 100 to use it instead of the Tacoma.
I would go double axle if it's an option in the sub 4k lb range. My trailer was a single axle with the axle towards the rear of trailer. Not difficult to back up, but tandem makes it a little easier, trailer will tow better, less wear on the tires. The tires on mine were about 4 years old (too old) and had the tread separate and blow a hole in the fender and interior of trailer, was just a pain to deal with and have fixed.
You’d have to ask the government agency that makes policy. DOT in most areas I’d guess. I think the rationale is that trailers are subject to different load forces and conditions, and that ST or trailer service tires are built and tested for that. The problem is, not everyone is willing to spend the money on Goodyear Marathons or equivalent name brand tires and you end up with people (and most manufacturers) installing Chinese junk like “Good Ride” tires.
I run truck tires on some of my trailers (like my fishing boat trailer), but on my commercial trailers I use ST as that is what they have to have when they are inspected. People run whatever they are comfortable with, regardless of legality. I’m ok with bending some rules and breaking others, but that’s entirely up to the individual.
