RV Tow Question
I've seen the internet folklore about some jurisdictions not allowing LT tires on trailers, but I've never seen anyone post a link to an actual law on such. On our first trip, we blew both of the original tires that were 3 years old. After that I upgraded to LT Tires and feel much more confident.
I'm not aware of any Federal requirements or NHTSA regulations for 'replacement' tires. There ARE regulations and standards for the tires that are on the trailer at the point of the 'first retail sale'.
Now that is not to say that local 'ordinances' can not be enacted, but I've never seen any concerning replacement tires.
ST tires (most) are designed to have thicker sidewalls than (some) LT tires. ST tires basically are designed for vertical forces. Some trailer manufacturers provide LT tires on their units right from the factory, but most put the cheapest thing they can buy on new units. LT tires are designed for tread wear, traction, lateral forces, etc...and are just generally better built. But don't think that you can overload them, under-inflate them and run them 80 mph on an RV trailer. ANY tire can/will fail if you abuse it.
IF you 'replace' your tires...it shouldn't need to be said that you will need to replace the ST tire with a tire that meets or exceeds the load rating of the one you took off. There ARE ST tires that will hold up, but they are F and G rated tires and you will NOT find them on any trailers (from the factory) that I am aware of.
You can run factory ST tires if you like. And IF you don't use your RV much, go very far with it, or load it up (as most folks do) with a bunch of stuff, then you'll probably be O.K. for awhile. But...look at what experienced RV'ers are using. Talk with folks about their experiences towing and if they've ever had a blow-out.
Then Decide.
Be safe, have fun.
Yeah, that’s my main concern aside from max tow weight. Thanks all.
@bucfl We used to tow a 22' cuddy cabin with a dual axle trailer around Pinellas County with our 2002 Land Cruiser. We also towed our 2014 Caddy XTS on double axle U-Haul car-hauler (+/- 5,000#) back and forth from Clearwater to eastern Virginia without any issues. Had to go up some steep hills in our friend's neighborhood. Had plenty of power at 25 - 30 mph up 12% grades in the hills. No problems with I-95 and the flat FLA highways.
I second (or third) the advice to buy a dual axle trailer. Having a blowout with a single axle trailer can result in a very serious (i.e. deadly) accident at highway speeds.
As the owner of both a 2006 LC and a Ford 6.7L F350, I thought I'd weigh in here. We own a Jayco 24' RV as well as a M1102a2 that I built up and I've towed both trailers with both rigs. The LC does fine with the Humvee trailer but we obviously use the Ford for the Jayco.
While I do realize this is apples to oranges, you gain a real appreciation for the attributes of a truck engineered to tow vs. a fantastic off road SUV that can tow within reason. The LC does waaaaay better than it probably should and is surprisingly capable. Where you really notice the difference is not only power (obvious) but when things go wrong: sudden braking, swerving, bad road conditions, etc... All of which WILL happen to you at some point. The Ford will keep things fairly civilized while the LC will react like a SUV with mid sized brakes and a shorter wheelbase....Point being, it's definitely not about towing power but about handling and braking that keep you safe and relatively stress free.
My advice is to play it safe and buy a dual axle trailer maybe one step down in size than you "can" get away with. You'll be happier and safer in the long run without the white knuckles. Too many folks only consider what speed they can yow and don't consider deceleration.
We are leaning towards this one. It’s a little more than planned but has the safty features I’m looking for and the wife’s wants.
winnebago micro minnie 2100bh
  • Exterior Length21’11 »
  • Exterior Height (including A/C)9’8″
  • Exterior Width7’0″
  • Interior Height6’4″
  • GVWR (lbs.)7,000
  • Dry Weight (lbs.)3,760
  • Dry Hitch Weight (lbs.)430
  • Axles (lbs.)2 @ 3,500
  • Tire SizeST205/75R14
  • Fresh Water (Tank Only) (gal.)31
  • Black Tank Capacity (gal.)25
  • Gray Tank Capacity (gal.)25
  • LP Capacity (lbs.)40
  • Awning Length13′
  • Furnace (BTU)18,000
  • Water Heater (gal.)6
Thoughts?
I like the specs of that Winnebago Micro Minnie 2100bh, especially the 7' width which might not require slapping on Towing Mirrors.
Attached is an Excel Spreadsheet Towing Calculator filled in with my specs for my 2002 LX470 towing a Coachmen 192RBS <-- slightly heavier than your Winny. Depending on how much the people in your LX/LC weigh, and the cargo you are carrying, you should be OK with that Winny.
Crap ... this forum won't let me post the Excel Spreadsheet. Shoot me an PM and I'll email it to you if you are interested. Here is a PDF instead:
Thoughts?
Winnebago is a respected name in the RV industry. Been around a LONG time.
You would do well to stick with major brands (Winnebago, Keystone, Jayco, Forest River, etc....).
If your budget allows....I would recommend you purchase an RV with fiberglass exterior walls and end caps. They seem to do better than those with aluminum siding and are easier to maintain.
Stay away from cable operated slide-outs. Hydraulic, or gear driven units are the way to go. On small trailers, storage is usually at a premium. So look for thoughtful designs like 'pass through' storage (at least one) that will allow you to carry/store longer items.
You'll want LED lighting (not incandescent). Most are LED these days anyway..but the LED puts out more light and draws MUCH less amperage. Remember, smaller trailers will be 30 amp. (load) and its pretty easy to get to that maximum especially if the trailer you choose has A/C.
Tell the wifey to leave the 2000 watt hair dryer at home and get something smaller. ;)
Electric tongue jacks are nice to have especially if you plan on using a weight distributing hitch.
Some manufacturers of smaller trailers are using Aluminum framing (where they can) to save weight. Always a plus. Ask about that.
Outside shower (basically a hand held spray nozzle) is a handy item that is often used.
If the trailer has an awning (most do these days)...make darn sure you roll it in when the trailer is unattended. An unexpected strong wind WILL fold them right over the top of the RV and usually pull the arms out of the side as well.
^^^^^^ Just a few things to look for. We could spend hours discussing RV's and their features.
This.
^This is why I don't have an RV anymore. Tried towing it with my v8 4runner, any road situation more difficult than flat ground and 60mph was not fun to tow. I had a early 2000's F-150 that had less power on paper, but the gearing and length of the truck made towing a breeze. If I ever have a need to tow heavy / long again I will go straight back to a long pickup.
