Rust and Mud?
california
Hello 55er... im working on my piggy Penelope, doing some rocker panel replacement. Seem my piggy got some fiberglass repair and rust ate all the metal covered by the fiberglass patchwork.
typical...get after it! good work.
So did I... be sure to seal and paint the inside and drill a couple drain holes even...I didn't...
Thanks for the advice, i did a rust converter, but gonna primer and paint it also. I'll be drilling holes too. Where should i drill and how big is the hole? Thanks
That's on my list for sure. How much did you cut out?
If you cap the tubes why would you put drains in them?
I cut most of the lower part, left the upper where the door meet the rocker.
The hole might be for the moisture?
LAMBCRUSHER might have a better answer.
